UFO propulsion theory....
Started by infringer, June 17, 2010, 11:21:40 PM
infringer
Mixing, mashing, and banging ideas in my head I have plenty of ideas many I never share because I feel them to be profound or simply profoundly stupid but I believe I will soon change my course.... There is no idea too stupid one idea can lead to another idea and maybe several after that we attain something of value.
Black holes are interesting pieces in space... Many speculate much about them mainly Stephen Hawking. He is as in depth as they come. All of this is comes from memory and is simply theory that follows so if I am wrong please do correct me in the continued portion of this.
People speculate black holes to be mass compacted into a very small space, different things are believed to cause this. The death of a star is one of these things. So basically if we had a grain of sand that weighs a ton essentially this may be the makings of a black hole. maybe it would even take far less weight for a grain of sand I am really unsure.
Now if I also am correct it is said that negative particles are collected and protons ejected on to the event horizon...
My speculation from these conclusions are like this:
Black holes are simply create the conditions of antimatter as it sucks in these negative particles it is working like anti matter and all of the energy is contained by this black hole after all the forces of gravity are so great that not even light can escape the depths and it completely bends space and time.
The mass is 100% converted into energy without losses.
Now if we could take our grain of sand and somehow start the conditions for a black hole and contain it via some means which I will leave for others to work out maybe a full circle of negative magnets facing the negative poles and all the energy positive protons on the event horizon keeping it apart there is surely enough trash in landfills to throw into the black hole. Heck our waste alone may run the ship from here to where ever. If we were to then collect the energy from the event horizon I believe we may have some crazy amount of energy to use.
This is my way out there wild theory on propulsion of ufos.
One other thing that has brought me to this theory is at the center of many flying disc UFOs there seems to be a black spot it somehow reminds me of a galaxy with the black hole at the center even in the smoking gun videos it appears that the near see through crafts have a difference at the center. The other odd thing is it looks as if they are a pizza with a tiny slice taken out. Just observations.
IF YOU LOVE OR HATE THIS IDEA PLEASE DO SHARE WITH ME WHY OR WHY NOT?
It took a lot for me to even come up with a plausible theory!
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
Cloxxki
Nassim Haramein holds the theory that black holes have a white hole on the other side. Black compression, white expansion.
When we see expansion, we associate that with having missed the Big Bang. The latter being a moment, rather than a duration (white hole).
To extract mega energy, to be wirelessly transmitted (proven possible by Dr. Stiffler), you could locate 2 asteroids at different, but nearly colliding paths. Span a wire, stick it on the one, and put the coil on the other. Energy to be extracting (the wire being pulled) equavalent to the resulting mass*velocity vector of the 2 asteroids. I know, impossible, but there's A LOT of conventional energy out there not being harvested.
gravityblock
Quote from: infringer on June 17, 2010, 11:21:40 PM
Good observation!
That tiny slice that is taken out is more than likely due to an inverted field.  This tiny slice taken out can be seen in the objects shown in Nasa's Tether incident experiment.  Below is a picture of an inverted field by removing a piece of the magnet.  Here's an excellent video demonstrating the effects of an inverted field in a HPM, http://www.andrijar.com/homavi/motor.wmv
GB
infringer
Interesting read by Keely which was kinda along the lines of my theory in a way thought I would share...
Speculation on Keely and his method of anti-gravity focuses on 2 areas.
For Thrust (or levitation)
An artificial neutral center is created which causes the natural neutral center of the test mass to be drawn towards the artificial center with an attraction proportional to the energy flowing through the artificial neutral center.:For Weight Increase or aggregation of additional mass:When the artificial neutral center is superposed onto the natural center, the aether flows increase proportionate to the entraining amplitudes flowing through the artificial neutral center thus causing an increase in weight and a gradual INCREASE in the mass density.
For Levitation
A wire or ring is placed around the object. The ring is fed with a frequency that resonates with the neutral center of the mass. Such a resonance, properly directed can cause what Keely calls "high vortex action" to decrease or increase the aether flow through the mass neutral center. This flow creates the equivalent of a soliton, or a self-contained standing wave' with extremely high rotational velocities on the perimeter of the mass. Such a flow directly controls the "weight" of the mass by exceeding the Flotte 'Z' axis or better stated, by creating a higher potential in the mass aggregate than that of the surrounding media for ejection of the mass to one more favorable to its energetic level.
Keely also reported a cooling effect of the local air when the anti-grav effect was in operation (likely an ion wind).
Cavitation, Implosion, Water Hammer Effect
There is a connection between Viktor Schauberger's biological vacuum, and Keely's Neutral. Dale Pond has studied this up to a point.
Viktor Schauberger (or Callum Coats, translating Viktor's work) has referred to Keely a few times in his writings.
About a century ago, John Worrell Keely figured out how to run a motor on the power of cavitation or implosion, while alternately compressing and expanding water. He harnessed that we dismiss as nuisance- the water hammer- in water pipes. Dale Pond, researcher of Keely's physics, says that Keely's Hydro-Vacuo motor created a water hammer shock wave which when synchronized with the wave's echo, "results in Amplitude Additive Synthesis, a process which tremendously increased energy accumulations in quick order." Pond warns that this resonance amplification is similar to the process, which breaks wine glasses. from http://www.emfsafe.com/implosion/water.htm
A valve closing in 1.5 sec. or less depending upon valve size and system conditions, causes an abrupt stoppage of flow. The pressure spike(acoustic wave)created at rapid valve closure can be high as five(5) times the system working pressure. from > http://www.plastomatic.com/water-hammer.html
Dale Pond, in the SVP basics video, claims that John Worrell Keely's etheric forces and Neutral Center, have a lot to do with cavitation, or implosion, or the water-hammer effect. This water-hammer-effect is what they try and NOT do in normal engineering. same with vibration, again.
Callum Coats
in Living Energies, Callum Coats prints these estimates by Keely:
Molecular Vibrations 100,000,000 per second
Inter-molecular vibrations 300,000,000 per second
Atomic Vibrations 900,000,000 per second
Inter-atomic Vibrations 2,700,000,000 per second
Aetheric Vibrations 8,100,000,000 per second
Inter-aetheric Vibrations at 24,300,000,000 per second
Home-grown sine-wave experiments for software musicians
Punch in Keely frequencies 620hz, 630hz and 12,000hz, run through oscilloscope and watch.
Related pages
Klimator spinning wavy plate generating vortical movement of medium, generating cold or warm air = Viktor Schauberger related airconditionin device
-infringer-
