New Steven Mark video released April 2006 !
Started by hartiberlin, April 14, 2006, 12:18:43 AM
Mr.Steven Mark invented a superconductive amplifier,
a MEG with a superconductive coil,
not more-but also-not less !
I am only interested in the coil manufactoring process,
the rest:08/15 procedere !
Adolf Zielinski"superconductive amplifier"-level:input 1KW-output 1000KW,
recitating his published(real?)numbers !
Sincerely
            de Lanca
p.s.: I am not from the toroid(-al) party,I am EI-user !
oouthere
Superconductive???  He uses standard copper wire.....
Rich
The only "patent claims",and this is the barrier, are coil related- not for a "TPU"-concept !
S
  dL
Liberty
One of his first units used bailing wire and a magnet on top.  Kind of like picture hanging wire.
I think the device is much less technical than most of us are making it out to be.  He found it through experimentation, using common everyday materials along with high tech lab equipment (probably an O-scope) and some electronics.  We can too, if it is the real deal.  The best unit to study is the one where it is not all taped up.  It shows copper windings on the lower half.  Dual windings I think.  One for each bulb circuit.  It also has two magnets near the upper ring on opposite sides.
    In that film, Steven said that it was just the special interaction of the coils.  "Coils are very important".  I think that there is also a capacitor that is black in color mounted near the center of the device.  The picture does not allow a clear view of how it is wired.  But due to the nature of the device, it must use some sort of feed back loop to continue the oscillation at about 5khz.
In later devices, it appears that under the tape, that the two magnets are on one side of the upper ring and the magnets are together, probably in attract...
Liberty
Liberty
I have looked at other similar devices that have used iron wire in a coil around a magnet and zinc as the voltage receptor.  Something about iron wire seems to yield some interesting results.  Perhaps the iron wire should be used from magnet to magnet to set up the frequency?
Liberty
