Conspiracy smashes again an HHO succesor !!! ( sorry for the bad english )
Started by plam40, July 07, 2010, 01:11:08 PM
the_big_m_in_ok
With respect to the whole thread subject, has anyone thought of this in particular?
http://www.blazelabs.com/n-aquagen.asp
I've read that if you mix this gas with air, it burns.  Otherwise it's safe.  I believe it'll do about the same thing as Brown's gas.
--Lee
sparks
    HHO on demand is interesting if it can be an exact fuel replacement for atomized hydrocarbons.  It matters little about the efficiency and closing the loop etc.  If you can take a battery bank throw it in the trunk and run your car from hho nobody needs the oil companies cause we can charge our cars from the domestic grid or solar or wind or waves or whatever.  You just need a way to charge your battery bank.  This added to increasing the efficiency of the machine like using thermoelectric generators instead of radiators and dynamic brakes instead of friction pads and acoustic generators instead of mufflers etc the life of the batteries should be extended,  At least get you a good 30mile run from a charge with ac and heat.   Thermoacoustic generator can also be a thermoacoustic refidgerator.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
plam40
Quote from: sparks on July 09, 2010, 11:03:41 PM
What you are doing is a missleading the public ... With other words you say - " lets not use oil, but still be dependent on some source of energy - electricity !  Who is going to invest 20000 $ for a solar system just to be able to charge his battery pack which costs another fortune - just to be able to drive some 30 miles ?
  The real thing is a self ruining device that needs nothing but water !!! It is real, it has been done, it is working, it is possible. You've been shown many times the proofs ! The guy from the video just showed that , Meyer showed that, Dingel showed that .... Mythbusters tried to cover it up, but actually proved it can be done, Anton cell team is another common example !
The Little secret most people are missing is the pressure reducer from an LPG system and that there has to be some amount of HHO stored for compensating the speeds up intervals !
Regards to all of the real truth seekers !
sparks
    I believe there is a way to produce a fuel like hho and it does not use an exotic free energy force but relies on kinetic energy of atoms and molecules converted into chemical potential energy as you find in Brown's gas.  I am sure that the alternator on the car is supplying the power to the battery which the cells are using as a power scource.  I am also sure that increased production of the cells results in an increased demand on the electrical system.  As an engine is overloaded the rpm drops the alternator puts out less current and unless there is a battery or reserve scource of current the engine will stall.  The battery acts as an hho storage tank if you will but it is actually an h2so4 liquid storage tank.  The point I was making is that a direct fuel replacement for hydrocarbons is what is needed and quickly.  That the fuel be manufactured on demand requires that the cells have the capacity to deliver peak demands even if this means getting into the battery store.  Storage of gases gets into all sorts of complications whereas electrical energy storage is quite straight forward.  Again I dont care if you have to add energy into the system from other scources that you can run an internal combustion engine on this fuel is an amazing discovery that can hasten in the clean fuel age.
Think Legacy
Spread the Love
craZy
This is great. Do you know if he intends to show plans on how he built this? Because I and every one else would sure like to build one of these. Glad the video is still around so all can see!!!
