These magnet wheels look set to run !!!
Started by Raj Balkee, July 10, 2010, 07:06:29 AM
Raj Balkee
Hello fellow forum members!
Getting ready to see the wheels turning?
Just as a reminder, look at my wheels design (below) once more!
Best wishes to all, especially to Thay!
Raj
Raj Balkee
For my good forum friends:
Pictures and final modified drawing of my first attempt at building a prototype of my ' Automatic Gravity Engine' under the current name of 'Magnet Gravity Motor'.
I had mentioned in last December that I would attempt a build in 2011. It march 2011 now, and the working prototype build has started.
The design is planned to use twelve diametrically magnetised cylindrical magnets which are not readily available in the market.
The prototype under construction in the pictures, has used only three such magnets, and has turn the wheels up to 45 degrees always in the same direction.
This is an indication that the wheels are being set to run.
N.B: It will take me another eights weeks to get the remaining nine magnets before a complete working prototype can be tested.
By the way, almost any number of magnets can be used to make the motor work and the more, the better.
Well I'll keep you all posted on my work.
Regards .
Raj.
Raj Balkee
gyulasun
Hi Raj,
Your modified drawing shows an almost centered rotor position with respect to the stator (or vice versa), I wonder why you had to change? Earlier you always drew the inner magnet circle positioned to the center point of the half diameter of the stator circle.
Also, there is a 50% included in the file name, what it means I wonder.
Very good you managed to start building and testing it, the best way to learn for sure.
Thanks, Gyula
Raj Balkee
Hello Gyula,
Thanks for showing interest to know more about my idea in here.
Yes, the modified drawing has changed in presentation, but not in the original concept.
My original concept was simply two cylindrical wheels, on one and the same axle, on the same vertical plane, using magnets to interact as shown in the drawings.
But look at the lines of interaction between the different magnets of the wheels. You will notice much less sticky points in my modified drawing.
And then, even if the inside small wheel is almost at the centre of the larger wheel, the larger wheel's inside very small rim, still rests and rolls on top of the axle of the small wheel.BY THE WAY, the modified drawing must be used in an upside down position, to match my prototype build pictures. Please note that the diameter of this axle is half the diameter of the small inside rim of larger wheel, which mean that the same original synchronised positions and motions of the magnets is maintained.
As for the file name, it is only to remind me the size of the picture, that is, half the size of the original picture.
I have tried to answer to the best of my ability.
Regards.
Raj
