Chalkalis Gravity Wheel
Started by teslaalset, July 10, 2010, 08:52:57 AM
sm0ky2
Quote from: lespaul109 on July 24, 2010, 09:40:41 PM
now is the time when I ask for ideas about how to extract energy(electrical).........anyone
nice work. i would look at adjusting the distance between the rotor and the drive-wheel. it looks from that video that its knocking pretty hard, maybe a little "too close" together ??
it should rub enough to kick the rotor around, but probably shouldn't be jolting the drivewheel back like it is in thiis video.
im sure theres a lot of power lost in that action.
"strain" on the motor or whatever...
lespaul109
lespaul109
ok, tested my motor that has two coils. Each produces 8v peak to peak @ 300rpm. My drive motor needs about 3v @ 600mA can some one tell me how to wire both coils using diodes and/or rectifiers and caps to power my DC motor? Color codes are:
Coil 1: Yellow & Black
Coil 2: Red & Grey
thanks,
jake
tbird
hi jake,
you've been a busy boy!!  well done!
did you check the rpm of the main shaft?
2 volts x .6 amps = 1.2 watts...not much needed to keep it turning!  what rpm was that wheel?
i'm not the best here to tell you how to wire, but if that is dc output from your motor, the 8 volts from each coil should be enough to run your motor. if you hooked the 2 in parallel, you would still have the 8 volts, but would double the amps available.  of course if the rpm is much less than 300, so will the voltage be.
i guess there are others who can ask better questions and give better answers.  let's see who will speak up.
again, GREAT JOB!!!
tom
It's better to be thought a fool than to open your mouth and prove it!
FreeEnergy
nice pics/vid lespaul109, i think i understand now how this machine is suppose to work to produce free energy/over unity.fascinating idea!
