Chalkalis Gravity Wheel
Started by teslaalset, July 10, 2010, 08:52:57 AM
FatChance!!!
Quote from: lespaul109 on July 25, 2010, 11:40:17 AM
ok, tested my motor that has two coils. Each produces 8v peak to peak @ 300rpm.
Did you test the motorgenerator output with a connected load?
A suitable load must simulate the needs of your drive motor.
Use 68R at each coil. Check the the voltage at 300RPM.
If it drops to much, like 5V or so, then switch resistors to 27R.
My drive motor needs about 3v @ 600mA
This sounds terribly inefficient. You need a motor with much lower no load current.
Most of your input is wasted while waiting for the pendulum to return.
Find an old battery operated tape recorder and try the motor inside. Those are
usually of good quality and have a very low no load current while producing pretty
good torque and speed. All to save batteries...
One of the motors I have scavenged, uses only 6mA no load at 800RPM at 8V.
That's only 0.048W and it's a lot less than your 1.8W input.
And it pretty much tells us that your design is far from from being close to OU.
Your only chance is to slash input power to your drive motor by 40 times or so.
FatChance!!!
I can give you another tip for improvement.
Scrap the drive motor.
Mount a small electromagnet in the same area.
Add a small magnet to the pendulum. Ceramics is OK.
When the pendulum swings close to the electromagnet it gets
attracted to the iron core and procedes instead of falling backwards.
When it get top dead center you just give a small pulse to break the
attraction and there you have it, the pendulum falls into next loop.
The good part is that no power what so ever is used while waiting
for the pendulum to get into position.
The pulse can be self triggered by a small Reed switch, simple and good.
You only have to adjust voltage to break the attraction from the electromagnet.
http://en.wikipedia.org/wiki/Reed_switch
lespaul109
those are some great ideas man will do my best
lespaul109
@fatchance
can you send me pic of this recorder?
thanks,
FatChance!!!
No, I have no pics, I have scraped the recorder parts a long time ago.
But I can update you with new fresh motor numbers.
I tested my motor yesterday at 8V to get precise readings.
It uses 4mA at 8V = 32mW, while spinning at 1020 RPM.
0.032W vs 1.8W at no-load.
I do think you need go digging for old recorders and test their motors.
Please have in mind that all motors will use more power at load, aka kicking the pendulum.
Anyway, I can't see your device having the slightest chance of harvesting gravity power.
All gain from the pendulum falling down, is spent when swinging back up to the spin wheel.
You will make the device spin just nicely by the help of a motor but any load to the pendulum
shaft will prohibit the pendulum from swinging back far enough for another kick.
Just to make it spin at shaft load, you must increase the pendulum falling speed by increasing
voltage and power to the motor kicker, and this pretty much nails it.
You will only see the motor input at the pendulum shaft. No overunity or gravity power here.
