Help with Ed Leedskalnin Riddle , any idea .
Started by Mk1, July 25, 2010, 11:45:22 PM
Do you enjoy this topic ?
yes
48 (80%)
I am listening . Keep going ! but its hard to understand .
6 (10%)
Your are crazy stop waisting my time , lol
6 (10%)
Total Members Voted: 60
scotty1
Magnetic Currents are made by concentrating, dividing then shifting the North and South pole magnets from one place to another....as Ed said.
"When they run in (that is, INTO) the coil they are in bulk form. The coil's part is to divide those little individual magnets from bulk form in small paths." Ed.L  (they go INTO the coil from the magnet bar) () Scotty.
"Now about the sphere magnet.  If you have a strong magnet you can change the poles in the sphere in any side you want or take the poles out so the sphere will not be a magnet any more. From this you can see that the magnet can be shifted and concentrated......" Ed. L
" This experiment shows that if you start the North and South Pole individual magnets in an orbit, then they will never stop." Ed. L
Each particle in the concentrated substance is pulled from the front and pushed from behind.
That is why we have motion.
"They are in constant motion, they are running one kind of magnets against the other kind, and if guided in the right channels they possess perpetual power. The North and South Pole magnets they are cosmic force, they hold together this earth and everything on it. Each North and South Pole magnet is equal in strength, but the strength of each individual magnet doesn't amount to anything." Ed. L
" One current alone if it be North Pole magnet current or South Pole magnet current it cannot run alone. To run one current will have to run against the other." Ed. L
" Gravitation must be caused by the matter in the middle of the earth, and more concentrated than Uranium. When Uranium atoms burst they release the North and South pole individual magnets that held the atom together, then the magnets scatter all around, but when the atoms burst in the middle of the earth, and many burst at the same time, they can only run from the middle to the outside. When the North and South pole magnets are running alongside each other and in the same direction, they have no attraction for the other kind. They only attract if they are running one kind against the other kind. When the magnets are running out of the middle of the earth, as soon as they meet an object they attract it, on account of the fact that in any object there is both kinds of magnets in it."
"This experiment shows two things, one that the magnets can be sent out in straight streams, and the other whatever kind of magnets you are sending out the other kind of magnets are coming back to you." Ed. L
So Ed is saying that the atomic bursts from the center of the Earth are sending out straight streams of BOTH kinds of magnet particles.
Those magnets particles are not attracting each other, but are attracting the atom orbits of the matter that is in their path...which is all of us.  ;D
Scotty.
scotty1
To read Ed's notes you need to concentrate, then divide the words up into small path's and shift them around from one place to another.  :D
Sorry...I just couldn't resist.  ;D
scotty1
Hey Mk1.
I missed your post?
You will find that I just cross reference Ed's notes into various points.
I don't add my own thoughts much at all, but I have dug fairly deep and can demonstrate physically almost all of what I post using Ed's tests. Otherwise it is just my opinion!
About the magnets in Ed's notes we can only deduct from a few points, but by applying some Platonic reasoning we can extrapolate a bit without it being our opinion, but more of a "must be" argument.
Considering a single magnet particle by itself we have to reason that nothing can emit from it, as it is the base of all things. It can only "be"
It has no field. It is what we observe as a field.
It has no field yet there are 2 kinds, and since they are equal in strength, they both have no fields but they have strength?
Where do they get it from?
Once you start thinking about the magnets themselves it gets a bit philosophical.
Ed also says that the magnets can orbit a neutral particle, which means that they must be smaller than the neutral particle.
Ed shows that the magnets in a coil are pointing various ways at different moments, so we can deduce things from that, never leaving the original path.
So in my posts you will see that I treat Ed's words as he meant them, and simply build upon them by reference.
I don't know if he was right or wrong as I haven't made anything to utilise his theory in a practical way, but I learnt about electricity from Ed's notes, and then learnt about "electrons" later, so I suppose I'm bias.  ;D
I like Ed's theory...it's nice and neat and simple.
The practical answer (if there is one) is probably in my head already but I just don't see it.
It would most likely be a combination of Ed's results, but there is alot of possibilities to go through until the right one is found.  :-\
Scotty.
ThothTheSecond
Has anyone ever heard of a treasure map that Ed left behind ? It was mentioned near the end of the "In Search Of" episode on Leedskalnin narrated by Leonard Nemoy.
david lambright
  screaminvern (2 days ago) Hi david, I finished respacing the pipe segments on my wheel. I energized it with a 12V batt. I have a geode about the size of a tennis ball, and yes I can see a glimmer around it, and as a matter of fact when I move the geode over the top of the pipes, approx. 3-4 inches above, there seems to be what you discribed as a vortex.
a comment from my youube chnnel.....david
