Help with Ed Leedskalnin Riddle , any idea .
Started by Mk1, July 25, 2010, 11:45:22 PM
Do you enjoy this topic ?
yes
48 (80%)
I am listening . Keep going ! but its hard to understand .
6 (10%)
Your are crazy stop waisting my time , lol
6 (10%)
Total Members Voted: 60
sparks
    This patent pretty much sums it up for me and Leedskalin.  The flow of virtual particles which impart charge to mass reminds me of Leedskalin's magnetic currents.  These virtual particles have to move when charged mass moves.
The scale up of this machine is infinite.  The mass of the dielectric seems to be the scalable parameter.
http://www.rexresearch.com/gravitor/gravitor.htm
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
sm0ky2
i still have a hard time accepting that its a non-man made signal
SETI has spent decades looking for things like this.
if its not ours, then something made this.
stars and other celestial objects do not emit consistent signals like this.
even pulsars (which have the most consistent frequency of all stellar bodies) fluxuate somewhat, and emit all kinds of frequencies, in addition to their most noticible "pulses"
this is a perfect signal. signals like that just dont appear from solar fluxuations, even the orbits of stars around the galaxy, and around each other are not consistent like this.
to know more about it, i would have to gather some information about googles' system, i.e. sampling rate, magnitude,
in order to obtain the frequency / amplitude of the signal.
that would help narrow down its source.
if its not from our own satellites transmitting to and from one another, then it has to come from somewhere... something / someone... as far as i know, we have not located any intelligent signals originating from anywhere outside of our own creations.
if this is indeed Un-manmade...  i could argue that it is a sign of exterrestrial life/intelliegnce.
This signal looks very familiar to me. it looks like several thousands of signals i have worked with over the years.
what i see here is:  carrier wave, modulation wave, and the center one is the "data".
this only occurs from man-made communications.
we invented this form of data transfer.
i agree, it does ressemble the vortex map, and if it were out of phase 180-degrees things may be much different, but this is 230-degrees apart and of the same frequency.
notice that the freq. of the carrier/modulation waves are much higher than the data signal, this is done so it can be filtered out at the recieving end.
many things can take on a similar shape to this,. plot the path of a three dimensional orbit on a 2-d map. it looks just like your vortex map. heres an example of the space shuttle when it orbits around the equator.
http://www.aerospaceweb.org/question/spacecraft/q0282.shtml
i think if this were just some "occurance" originating from space, it would be "incoherent", a mixed jumble of several indecipherable frequencies. not just the 3 normal sine-waves that we use in everyday communications.
sm0ky2
one thing i am noticing here, if you pan to the left and right
is that the "data" signal isnt sending any data, its a HeartBeat.
like a computer system in a loop, waiting for something to happen.
(like ,.. just a guess here, perhaps a missle launch?)
it could be something completely different
maybe the global positioning system, but im not sure if that particular system operates in any "IR" frequencies..
its also possible that the signal itself is not even in the infrared spectrum, but for one reason or another, its showing up on googles image.
[correction] i take that back, this isn't a repeating cycle, this is the same image, overlapped on itself. we're just seeing a single snapshot, one tiny piece of space. using the left/right arrows just repeats the same image.
Mk1
@smoky
They know , the historical map is way older then all our technology and it clearly shows the same thing , what gives .
The sorcerer know about astrological events otherwise the king has his head , we are living it as we speak we are entering midpoint now it takes 7 years , The king need to know that stuff to take full advantage of it ...
Lenz law dictates that earth like a coil is producing a magnetic field to counter balance the field made by the galaxy an i think the small one is the solar system. This explains the lay lines from the world grid , its the lenz thing and the lenz thing may actually give life to a planet .
Now the harmonic freq the galaxy must dictate the root of the note or freq , sub systems like the solar system needs to be in Harmonie with it otherwise it will get rejected , 230 you say i guess i have no idea , but i bet its a ratio of 1.618 the ratio of beauty and life ...
Also we did not have the technology for infrared in the old days and don't see it anyway , so i guess it is easy to ignore , the compartmentalization of science and building of unique language for each field only serves the employer , in life you do what you get paid for ...
This is some crazy stuff , but there is a simple elegance to it , some can't accept those , in truth it fuels me .
sm0ky2
correct me if im wrong here, but is not that "historical" map, showing the path of the EARTH, in its 3-d orbit, passing through the constellations, drawn on a 2-d map,
like in the space shuttle link
during the 3 phases in its cycle?
why would this identicle pattern show up on goggles "IR" view?
is this something Google Sky added to the map, and is not really "there" ?
this is all making me want to get some more infrared images from other sources to compare them.
also,. if this is actually "seen" in the sky, how far away from the earth is this signal?,  does it circle the earth? does it travel in a straight line, through that one "window" of space the google telescope is pointed at currently?
