Thanks to ALL for your help!!
this will get rid of arthritis.
Started by 11:11, July 29, 2010, 08:57:46 PM
giantkiller
I did not know it was mandatory to click on all threads. What ever to freedom of choice?
I agree with 11:11 wrote.
The human body is an overunity device. Look at the crap one feeds themselves and they can still breed. Amazing....
Look at the poisons one can consume and still live to be 80? Amazing...
It has to be overunity. Look at the little bit knowledge it takes to spew at others and think there is control. Oops thats labeled 'Insanity'.
11:11
giantkiller.
there is no reason why the human body, cannot live to be several hundred years old.
the biggest problem is adding telomerase to the ends of the DNA strands, so that the DNA strands take longer to unravel.
the second biggest problem is continuing to intake required materials, for the body to function.
such as tens of different kinds of atoms.
off of which the body gets the frequencies that it needs,
to function.
and remaining alkaline enough,
to kill off disease.
and to avoid acidity from sugars and fats enough,
to prevent chemical disintegration of tissue.
i think that in ancient days,
some humans did live to be as much as 700 years old.
because there was a source of telomerase in their diet,
they only ate alkaline fruits and vegetables,
and they had lower levels of stress.
(they didn't become target practice in forums,
for trying to do good deeds,
free of charge.)
there is a man named peter ragnar.
he is likely around 70.
yet he can run marathons,
lift up hundreds of pounds,
and beat the crap out of professional boxers.
peter ragnar has been studying how chemicals and magnetism effect the body.
which is the source of his physical ability,
to beat up anyone who chews on his ass.
anyone who is serious,
about expanding the expiration date,
on the hamburger meat that they are riding around in,
should look into peter ragnar.
though i doubt that even peter ragnar knows,
about the bane of acidic hydrogen/carbon.
because chemistry is a hard thing,
to concretely see the effects of.
crowclaw
11.11, Thankyou for your valued contribution to this subject. Many people suffer from this terrible health problem some worse than others. My Wife has this progressive condition affecting her wrists and fingers and other joints are starting to show signs. At 62 she still works virtually full time in a her job as a personal shopper which is quite demanding of her. She has to wear strong supports on both her wrists, and she considers herself far better off than many others with this condition. Now I'm an electronics engineer and have been experimenting with various forms of electronic devices in an attempt at least to releave some of the discomfort from this terrible complaint.
This forum is all about sharing information and helping others... just keep it coming. For those who are quick to criticise and complain consider yourself very lucky if you are fortunate to experience good health.
11:11
crowclaw.
2/3 of human health, relates to energy.
the remaining 1/3 is based on physical matter.
though that 1/3,
is a foundation,
upon which the 2/3 energy must be built.
once your wifes body is more alkaline,
and she has the benefits of turning the apples vitamin C,
into connective tissue and collagen,
then the next step would be to focus on exposing her to negative ionization.
negative ions are obviously any molecule,
that is carrying an extra electron.
negative ions are extremely important for human health.
you need them to reproduce new cells,
for your nervous system to function properly,
and to boost your bodies electromagnetic field.
positive ionization is common.
positive ions are molecules which are missing electrons.
which might as well be a car engine that has no motor oil to lubricate its moving parts.
positive ion is chewing the population up,
at least as badly as too much hydrogen/carbon is !
positive ions form on the negative half of every capacitor.
negative ions form on the positive half of every capacitor.
if you stuck the negative terminal of a power supply in the ground outside,
and you attached the positive terminal of a power supply to a large chunk of metal,
and your wife sat next to the chunk of metal,
than she would be sitting in a cloud of negative ionization.
you could take the power supply out of a $40 microwave from greed-mart,
and use that as the power source.
a $40 microwaves power supply, is about 700 volts at 0.3 amps.
that would rapidly convert into 2,100 volts at very few amps,
due to the charge building up,
against what amounts to a brick wall.
as long as nobody near the metal plate is grounded,
and nobody directly touches the metal plate,
it shouldn't hurt anybody.
like being next to a fire won't hurt you,
as long as you don't touch the fire.
the negative ionization will only build up,
until it reaches the positive outlet, on the nearest electrical outlet.
the positive outlet will suck up the negative ions,
and send them through the cities electrical grid.
so don't set it right next to an electrical outlet,
or else there might not be enough negative ion build up.
crowclaw
11.11 Thanks for posting again,  looks very interesting... I must try this out, although the use of such high voltage is a little scary!!
Are you familiar with Lee Crocks_ "energy cleanser" device (Google search for info) using a 3 volt source and switched +ve / -ve & -ve / +ve every fifteen Min's to a conductive screen. I'm currently trialing a similar version.
