Core saturation and Lenz.
Started by broli, August 02, 2010, 08:35:34 PM
Omnibus
Quote from: cletushowell on August 08, 2010, 01:48:07 AM
Ill give you my Advice send me your
math ill compute it through the axis of infinity
make shure it right before you start beings I have string theory
and am the first to the math to double the speed of light
so dont know how to slow time but i can speed it up
you need a v shape create a black hole and water
or enough energy to warp like einstien
v hull philidelphia
noahs ark
and time traveler video
the water and pipe to earth battery
Isn't there a way to make clowns such as the one who wrote the above stay away from the discussions?
@broli, this is a very interesting idea and I agree with the previous participants that it appears very much similar to what Steorn do, unless I'm missing something. It would be interesting to hear what @Omega_0 has to say about it as the first one who has independently reproduced Steron's eOrbo overunity claim.
cletushowell
I said it was my advice odviously you didnt take me serious
i said i have string theory
I have the math axis if infinity so if you give me your math
I can calulate it to see if its right or do it yourself
12 144,000 12,000
every number reduces to 1-12 and goes thru 144,000
so I eliminated the decimals solved the necerending 2.333
7/3 =2.3333 wrong
7x144,000 = 1008000/3 336000
a perfect number so you can now see you made a mistake
have a good day
lumen
Gee,
So we should solve all our calculations based on religious beliefs from our perceived reality instead of directly from the perceived reality we believe we are in?
Ok, I finally see it! (now go away)
cletushowell
No try to do it your way you cant so its not a religious
beleif its a fact I solved the math
but you must have gad the answer already
of the 2.333 so you know how to make teslas earth quake
then i guess were even
lumen
Well, I did a test on the amount of inductance change and I was able to get the coil of 450mH to change down to .04mH when saturated by a PM. This shows that a change of 1000 to 1 is possible.
Another interesting effect I noticed during the test was, if the core was only partially saturated using tiny magnets to a point where the inductance read about 15mH then, rotating the setup in the earths field would show a change in inductance of about 1mH.
The coil was toroidal, so I think the next step would be to wind a simple coil using the same ribbon core material and test it again, and also test the increase in pull to the magnet when the coil is energized.
I'm thinking this setup would provide some additional information that will not show up using a toroidal coil.
