Core saturation and Lenz.
Started by broli, August 02, 2010, 08:35:34 PM
cletushowell
What exactly are you trying to do
reach 1
3691888
there wind the coils reverse spiral thru
sheetmetal shit i turned brain to one energy
you want 1000 magnigication
369 add 3 to your coil each wave
you want contained saturatution
of magnetism use the car coil
contains frequency
you want earth quakes like my aug 13- now
marina islands use 369
210. Mv
you want wireless transmision
of 120 volts stick the postive
wire to the car coil spark plug side
then you get 120 wiresless on other sidd
ground that to 3691888
then you have complete loop
you want dc ac photon
plug iphone charger in wall hook negative
side to car coil
get ac /dc 1.2 ghz in same wire go back to ground
over unity unmettered energy
1.2 is exact center of everything sepersted
polarity and zero point
but you can move the 1 by dividing
by 13.5 to the right
and  pie is 144,000
144,000/9/6/3 =888888888
all numbers never ending
56,000/9/6/3 = 1234567910
so theres you two sides of
power but i seperated all numbers
from decimals have good day maybey one day you
wish you payed attention
cletushowell
3.141592653589793
141+ 3 leaves 0
9+5=14=7-7=0
144,000 3.14159
2+6=8
5+3=8
53=8
89=17=8
79=16 = 88
i can do this all day 100 ways
cletushowell
Because every number
= 8
88= 16=7
888=24=6
8888=32=5
88888=40=4 and0
888888=48=3=12
8888888=56 =2=11
88888888=64=1=10
888888888=72=9
8888888888=80=8
peace
Hope
You spoke of speeds to enter an exit the exitation periods at.  NO  NO NO     not that   instead find where they DRAW from and create a flux there impeed the flow  it MUST balance, so you then get power.
gravityblock
There is one thing that everyone is overlooking.  As the inductor is being charged, the flux isn't fully engaged with the core material due to the changing or increasing current. The magnetic field of the dual magnets will interact with any flux which isn't fully engaged in the core material and induce a BEMF.  If the flux is fully engaged and confined within the core material faster than the dual magnets can depart from TDC, then there will be no BEMF induced.  In order for this to occur, we need the current to reach it's maximum value allowed by the resistance almost instantaneously in order for the inductor to be charged and saturated faster than the rate of the dual magnets departing from TDC, which is related to RPM.
BEMF is proportional to the RPM and the charging time of the inductor.  Let's take the e-Orbo for example.  It may not have a BEMF at it's maximum RPM, but at some point above it's maximum RPM, it would suffer from a BEMF because the dual magnets will be departing from TDC faster than the flux can fully engage the core material in order to saturate it.
You can't just use any voltage/current/resistance/inductance/inductance change/ or core material you want and expect to replicate the Orbo effect.  Everything needs to be matched.  The bottom line is, if the inductor isn't saturated in less time than the rate of the dual magnets departing from TDC, then there will be a BEMF induced and any gains in inductance predicted by the math equations you can say good bye too.
GB
