Magnacoaster - Vorktex
Started by kyler, August 03, 2010, 11:45:23 AM
bolt
Quote from: Honk on August 04, 2010, 07:23:07 AM
Hi Bolt. Just ignore trolls, there are everywhere.
I have some questions if you don't mind?
1) Is the LC circuit on the output series connected or parallel connected with the transformer?
    But I do think you mean series?
SERIES...AND USE AN RLC ONLINE CALCULATOR TO GET VALUES CLOSE FOR L AND C'S TO MAKE RESONANCE TANK
2) In your LC circuit, do you say there is no inflow of current at the 110VAC input to the transformer
    when tuned correctly while the lamp being fully lit?
CORRECT THE REAL WATTS POWERING THE CIRCUIT IS USUALLY UNDER 5 WATTS.
3) How do you measure the voltage and current into the lamp?
    I'd use a series current shunt with the lamp and then measure the voltage across both the
    shunt and across the lamp by a two channel scope. Lamp wattage = Volt times current.
NO YOU CAN DO THAT  YOU CANT MEASURE RE DIRECTLY AS IT COMES FROM OUTSIDE ITS AN AMBIENT RESOURCE YOU CAN MEASURE THE VOLT ACROSS THE BULB THOUGH WHEN IT FULLY LIT AND WILL BE AROUND 12 VOLTS. ITS IMPORTANT THAT ANY R IN THE CIRCUIT IS EXTREMELY SMALL SO YOU DONT GO PUTTING SHUNT IN OR YOU KILL IT. THE REACTIVE AMPS WILL BE EXTREMELY HIGH IF THE BULB IS DROPPING 12 VOLTS AT 250 WATT THE AMPS = 20.8 AMPS. A 1000W BULB WILL DROP AROUND 18 VOLTS AND 52 AMPS!!!!!!!!
4) Have you performed this type of measurement to exclude power errors?
UP TO YOU TO CONVINCE YOURSELF YOU ARE NOT DREAMING WHEN YOU SEE A 250 WATT LAMP FULLY LIT RUNNING ON 3 WATTS. ALSO THE LIGHT IS A HAZY BLUE WHEN POWERED BY RADIANT ENERGY.
I hope you find some time to answer my questions?  ;D
It would be most valuable to all of us.
NOT ANSWERING ANY MORE ON THIS NOW DO YOUR OWN RESEARCH.
FatChance!!!
Quote from: bolt on August 04, 2010, 08:00:09 AM
You sound strangely angry Bolt.... could it be that your claim is not OU.
Why research? If you really had anything real going, you wouldn't need others to build it.
You could just as easily build it yourself and let it be independently tested.
If it was overunity you would get financial backing in a minute to develop it further.
I'm 100% sure you are wrong about the LC device, it's simply a measurement error
due ignorance in electronic physics and how to perform accurate testing.
mscoffman
@Fat Chance;
I think the problem is not lack of availability of devices showing
Overunity Energy, but severe lack of knowledge by the folks when
They try to prove or use the extra energy.  I can easily list seven areas of
knowledge required to build a “balance beam” system that doesn’t require any
instrumentation or calculation during demonstration of OU.  Easily done on you-
tube. I don’t think I have ever seen it done correctly. I don’t think the majority
of people have those areas down pat enough to demonstrate or even know
whether they have overunity or not. So it’s a near universal lack of knowledge
problem.
Even if ZPE explanations are all completely bogus there are several
“not very utilized” energy sources that could be utilized that are OU simply
because they are not thought about. A number of energy systems cannot
be looped because of implicit inefficiencies in Carnot cycle heat engines
and photovoltaic implicit inefficiencies wipe out energy gains when in a
loop.
How many Bedini systems have never automatically swapped a battery?
Nearly 100%. How many spiral magnetic motors using pulses to get
across the sticky spot have ever listed the pulse energy required to
do so. nearly 0%...See..This is what I am talking about. You can't
expect proof, just general storied validations.
:S:MarkSCoffman
mscoffman
On bolt system; Is it overunity? It's hard to say.
The light probably is not coming from the filament
the way it's supposed to but rather a glowing plasma
inside the bulb's near-vacuum. The high voltage excursions
of high Q LC resonance are capacitive coupled into the bulb so
the bulb would likely not have it's usually 95% inefficient
heat to light ratio, which is why incandescents need to be
gotten rid of. Of course there is no such thing as radiant
energy, just standard stuff.
Then on the input side I would like to see the system powered
by a 12VDC inverter of measured inefficiency so I could
see non-pulsed 12VDC power measurements which is the
*only* one most inexpensive DVM's can make.
It maybe somewhat overunity because of the free electrons the
high voltage pulses attract from the environment. I doubt
that it's enough to operate a 20% efficient photocell converter.
And I doubt it generating proper heat to do anything with.
You just have to know what you are looking at, is all.
:S:MarkSCoffman
kyler
is anybody else have an interest in replicating this patten(on a small scale. maybe 500W)?   I need a recommendation on magnet sizes are these desirable
http://www.kjmagnetics.com/proddetail.asp?prod=DX0X0-N52&cat=168
