Magnacoaster - Vorktex
Started by kyler, August 03, 2010, 11:45:23 AM
FatChance!!!
None of you guys have seen a real working overunity device. That's 100% sure.
And why should we read back on your post Bolt if you really know the secret of OU.
Just compile your knowledge, post it, build the device, let it be tested....or shut up lying.
You're a fine example of the typical free energy fanatic saying they "know" for sure it works and
claim they've "seen" overunity in action....but never produce any evidence or replicable blueprints.
If you so sure, then show us the money or continue your life as a mad free energy lunatic.
Don't get me wrong here. I would really love to see or build a working OU device.
That's one of my goals in life, but I don't go around fooling myself into lies.
Please Bolt, have an open mind when you run into claims without proof what so ever.
Btw, the chinese need their NdFebs for regular basis, like turbines, industrial needs, Ecars and so on.
kyler
Quote from: giantkiller on August 03, 2010, 05:41:39 PM
Now you are in my infoturf:
http://www.intalek.com/Index/Projects/Patents/DE3024814.pdf
Giantkiller Is this KUNEL PATENT enoth to make a few kW of power generation? Is this patten similar to the Richard Willis patten that bolt just mentioned
Bolt, I would think most people would prefer a solid state. less moving parts usually means less energy lost to friction and less parts to replace with time.  Has anybody built one of there solid state models and put some instructions up on the web for our benefit :)
gyulasun
Quote from: bolt on August 03, 2010, 04:55:35 PM
  Take a 250 watt light bulb and in series fit a capacitor and inductor selected so the i/p power is power factor ZERO.  The watts consumed and measured by any suitable test method will show leakage power around 3 watts when i did this. The 250 watt light is FULLY LIT.  The volts drop across the bulb is about 12 volts. The bulb works underwater perfectly fully lit. The power factor is virtually zero creates standing wave the bulb is powered by zero point energy for FREE.
its the basis for many many OU systems.
Hi Bolt,
Please allow me to play a layman's role for a moment... Do you not need here a mains transformer because earlier with the 500W bulb you included it here in the other thread:
You want proof? Fine take a normal transformer and load the O/p with a large series choke and a cap. Tune the inductor and or cap to create a perfect out of phase condition. The i/p power is almost zero amps apart from some leakage. Now put a 500 Watt lamp in series and the lamp will light. Re-tune the LC to correct for lamp impedance. The 500 watt lamp is now fully lit. THe volts drop accross the bulb is under 12 volts yet this is a 240 volt bulb.
The i/p watts is leakage in practice maybe 3 watts. The bulb is fully lit! HOW??? this experiment done hundreds of times. RE will power the bulb under standing wave condition. A standing wave condition is a Scaler Wave. The bulb work under water and you wont get a shock.  Tuning is a real pig you might have to spend half hour getting tuning perfect even moving  the lamp wire will knock it off tune but it works.
What you are seeing if you do this is Radiant Energy powers the bulb at Zero Point Nodes its the key to all these circuits. All they are doing is creating VARS yes even Bedini is power factor correcting the RE charge going into the battery.
I ask as a layman:
1) the setup needs or does not need a mains transformer?
2) What secondary voltage should have on the transformer if I use one?
3) If I  monitor Power Factor at the primary coil of the transformer do I aim for zero or one PF by doing the LC tuning?
Please answer.
Respectfully
Gyula
bolt
Quote from: gyulasun on August 03, 2010, 05:56:01 PM
Hi Bolt,
I ask as a layman:
Please answer.
Respectfully
Gyula
Its easier with a transformer because you can use the inductance of it to help slash the power factor to zero. On the i/p mains side you are looking at PF as close to 1 as this is the REAL watts. In practice its around 2 or 3 watts. If you use a Power Savers meter some actually show PF volts watts amps etc very cheap now.
The secondary of the traffo is part of the RLC loop this is where the PF = Zero or if you are RF trained the VSWR  =~ Infinity.  You need another traffo as series inductor and lots of motor run caps and tuning its REALLY REALLY REALLY REALLY DIFFICULT. If you sneeze it will go off tune i cant emphasize this enough otherwise people will say i tried it and it don't work LOL
You don't have to use a transformer on the i/p but i think it helps the tuning as it becomes part of the overall RLC circuit. If you do use a big one like 100VA+ Big things always tune easier. If you play with tiny wheezy toroidal cores its hard to get the tuning right.
The reason is RLC leads to OU where PF = ZERO creates scaler wave conditions under resonance. Radiant Energy enters system at NODES as electricity has nothing to do with electrons. Electrons are only a byproduct of waste.  Thats why they call it Electron Theory and not electron FACT... or the Electron LAW:)
OH BTW you can use almost any size bulb here. I know some have used 1000 watt light bulbs the i/p watts was about  EIGHT watts. To be honest i used a halogen flood light this was YEARS ago i don't remember if it was 250 or 500.
gyulasun
Ok, thanks.  One more thing what secondary voltage should the transformer have if I were to use a mains transformer at the input? 6-10V? 10-24V? higher?
