Thanks to ALL for your help!!
Engineers unveil Lutec 1000 free energy machine
Started by powercat, August 11, 2010, 05:11:19 AM
exnihiloest
Quote from: WilbyInebriated on August 12, 2010, 06:54:42 AM
or the pons and fleischmann of this decade...
Pons and Fleischmann published well documented papers on their work, they were not searching for funds and they didn't predict they will have a miraculous machine two years later. It is the opposite of Lutec behavior.
Such simplistic confusions would have let us waste our time in the past in studying Nostradamus instead of genius like Tesla or Einstein. To proceed, we must be smarter in selecting our sources of ideas and in avoiding swindlers traps, everything is not equal to everything or to whatever.
FatChance!!!
We could always hope for that, but actually there's no chance this being the case of the Lutec's......
WilbyInebriated
Quote from: exnihiloest on August 13, 2010, 05:22:20 AM
using phrases like "such simplistic confusions" seems to indicate that you seem pretty sure of what i meant... which is ironic, since by your response i can tell that you have no idea what i meant. ::) and where in the world did you get the impression i was saying 'everything equals everything or whatever'!??! is that some wild assumption or is that just a red herring?
supermuble
Can someone tell me how to delete my profile?
These types of threads are exactly why I want to delete my profile. The skepticism makes me want to puke.
In case you haven't noticed, The Robert Adams motor, from New Zealand, The John Bedini mechanical oscillator, the Steorn Orbo motor, and the Lutec motor are all using the same basic principle. It is so simple, I can't even believe there is a hint of skepticism.
It works like this: You have a wheel with magnets. On the outside of the spinning wheel you have charging coils with an iron core. The magnets will pull themselves to the iron core, without any input energy at all. While the magnet is being attracted to the iron core, the wheel spins without any input energy. At the SAME time the wheel is moving without any input energy, electricity is being created in the coil of wire surrounding the iron core. The magnet is moving without input energy, and the movement of the magnet towards the iron core creates electric current in the coil of wire.
Now at the moment the magnets line up with the iron cores, you will have strong attraction. However if you suddenly send a small pulse of reverse current to the charging coils, the magnets on the wheel will continue spinning, without hitting a sticky spot. When the machine is up to speed, the momentum of the wheel means that very little energy is required to cancel the magnetic fields of the iron core charging coils. During attraction you have FREE induction. This FREE induction is responsible for the over unity. Your not getting free power, you are harnessing the power of magnets.
If this is hard to understand, then go build a plywood wheel. Glue some magnets to it. Then hold an electromagnet by the wheel. Spin it with you hand and pulse power to the electromagnet. You can test this theory yourself. Why does John Bedini use the mechanical oscillator? Because the attraction of the magnets on the wheel to the iron core coils is FREE mechanical energy.
This is simple stuff. I can't believe anyone would argue this? I can't build one of these myself, but the theory of operation is not really difficult to understand. I think people need to do more research instead of blatantly dismissing stuff. I am not trying to be rude, but why are 99% of the people on this forum so stubborn and skeptical?  ???
TheCell
And if this works , it is also working with no moving parts.
See Richard Willis Vorktex Power.
My theory:
This small sharp pulse that is needed to compensate the magnetic flux within the iron core needs less energy than normally expected .
A small sharp pulse contains many frequencies.
(http://tesla3.com/free_websites/zpe_meyer_mace.html)
The iron isotope is changing thereby providing energy.
(21 MHz needed)
The core itself provides the energy, therefore must be replaced after sometime.
SR193 made a replication of the kapanadze device which in my pov is not the first design of kapanadze. He uses iron cores with this frequency of 21 Mhz and this  Isotope Transmutation process.
Can someone confirm this or is this simply nonsense?
Another fact that lutec and bedini are using big battery banks. Also
the first two Vorktex Power products are designed to use lead acid batteries. Here comes that bedini thing into play with battery as a radiant energy receiver. I ask myself, are this batteries really needed?
You need to have a iron core with a strong magnet field in it 0.5 Tesla. You pulse that core and with every pulse you will get extra energy by this  Isotope Transmutation process.
