Thanks to ALL for your help!!
Fuelless Engine Disk Motor & SP500 Generator
Started by FuellessPower, August 12, 2010, 11:23:17 AM
FuellessPower
Direct quote from David Waggoner "David Waggoner here, Yes the motor is overunity, and looping it back to run itself will be no problem. It is a free energy motor, not a perpetual motion device. The video shown here is only a small quick test. The HP of the motor is about 15 tp 16 hp x 826 rpms, we are still working on it to pin point the exact HP. The test ran so far show this motor can handle way more output than one 40 watt bulb. More tests and video to come. "
"Full specs not available yet. This is a new project of ours, just showing people a demo of our progress."
We are making ourself vulnerable to attacks on this forum, which is why we are posting here. Let us provide the information, then you can come to your conclusions. As I stated I am here to give updates and information on our progress.
FuellessPower
"No, he isn't. Closing the loop is not the only way to prove overunity. He should carry out very careful measurements of the input and the output power and that would be enough as proof of overunity if the latter is greater than the former. He hasn't done that yet, unfortunately, and that cannot be substituted by providing a list of satisfied customers."
Thank you, We plan on doing a full demo soon. Check back Monday or Tuesday.
ramset
Fellows,
Let the guy post ,
keep your wallets in your pockets!
Geese!
Chet
Thanks Grandma
Omnibus
A self-sustaining device is a perpetual motion device. That's in fact the ultimate proof that a device is a perpetuum mobile. Would have been much better to first have it as a self-sustaining machine and then announce it because we've seen a lot of these reverse announcements which ultimately turn out to be fake and that's the main reason for the skepticism.
mscoffman
Several things;
a) I believe this device probably is overunity because, if you
will notice, the stator motor/rotor is made from Teflon plastic.
This suggests it performs it's OU functions static electrically.
b) The flashing bulb is being exaggerated because the camera is
only partially synchronizing with the spinning motor rotor so the
flicker is probably exaggerated by the "beat frequency". The bulb
*is*  bright because of dimming of the rest of the room by the
camera's video AGC Automatic Gain Control when it is looking at
the directly at the bulb.
c) The "High HP" horsepower label is relative. The input power suggests
only .25HP mechanical torque is being produced by the motor. So
things appear to be in alignment with what is being demonstrated.
So I wouldn't be surprised if you found this motorgenerator actually doing
what is claimed. The OU energy output content is probably variable so it
will require additional buffering and processing before could be used for
anything useful. This Static-Electric Overunity and Cold-Fusion-Overunity
are energy sources that keep showing up in potentially real devices, so it
may be time to begin admitting them as real.
I would want to see an additional experiement showing 40Watts of heat being
produced after the lightbulb demonstration.
:S:MarkSCoffman
