High Voltage CFL Circuit
Started by nievesoliveras, August 14, 2010, 09:00:21 PM
nievesoliveras
Pirate88179
Jesus:
That is a ccfl inverter made by TDK.  This was all I could find so far:
Inverter : TDK TAD170 (5V) or 8m8619 (5Vor 12V)
Input current : 0,2A
Output current : 5,0 mArms
Drive frequency : 30 kHz (typ)
Interface connector
Used connector : IL-G-4S-S3C2 (*1)
Manufacturer : JAE
Pin No. Signal Name Function
1 HV High Voltage
2 NC Not connected
3 NC Not connected
4 GND Ground
I found this info here:
http://www.beyondinfinite.com/lcd/Library/Hosidan/HLM8619-010300.pdf
I hope this helps a little.  Seems to me a decent JT circuit will out perform this thing using an AA battery though.
nievesoliveras
Thank you @pirate!
Which joule thief circuit configuration you recommend?
Jesus
nievesoliveras
Thanks be given to:
@mrmag
@kooler
@amigo
@light
@pirate
I learnt with the information given to this point, that the secret of the high ac voltage output of this particular driver lies on an efficient use of a two transistor oscillator circuit.
I learnt the inner transformer connections except, the one related to ground.
Jesus
XS-NRG
not only the oscillator.
the frequency in relation to the transformer is also important.
most of these circuits run at around 35Khz unloaded.
Here is one 12volt in 1200volt out.
