Going thru time vrs between it faster then speed of light
Started by cletushowell, August 16, 2010, 05:50:42 PM
cletushowell
Well after doing a lot of condersering on how to explain
eistein was wrong about the fact you cant go faster then light i final
figured it out well first you need to double the power
this is done by backing up the light and spiral it thru water
taking multiple light waves and frequency prisim
together then in order to release these you need to chage the state of water to ice instantly forcing all the frequency out at once
but then you run into laws of psysics that says if your seperating
space time your not going thru time but there is no
time between the seperation hence your not going faster then light
so working on my antigravity demostration
the floating cup i noticed in order to continualy
levitate the cup i not only need to evaporate the water out of the cup
but condense it again the thru the cup
to evaporate again well now while writing this i solved that
the bottom of the cup should be cut out
and solid ice hence ice floats contracts the steam to water and continual levitation but that not the laws im talking about thats bose einstein condesation
but what im saying is in order to go faster then light
the light has to go thru you not around you
or at least thru your aircraft
so heres my example its a fish
first off you should know the fish is really close to the string theory design
with two flat blades but one is side ways it takes
energy in and redirects it thru the gills and the the last
thru the tail so its not really fircing its way up stream its
warping its way upstream
by redirecting the energy in the tail
time the water is going thru the fish not the fish thru the water
hope you get it probly not
cletushowell
Let me continue on this first off you need to understand the v
is the most important thing to warp time
but the double v is even mome important
and this is illistrated in my simple pillow theory
takingthe heat from your head and
cooling the bottom of the pillow
but lets look at some things
first the fish has scales the nasa space craft does to
the fish has a hole its mouth and gills
the rodin coil does to
the fish has wings the plane does to
the fish has a tail the plane does too
the fish is the design of tesla sub
but tesla didnt take water thru the sub
but power
so now we have all the basics for the design
but lets look at the bird the bird
warps time as well
has the fastest digestive system the black hole
the ability to take energy in and use it but then discharge it
so the food is the energy the water discharges the digestive system
just as water discharges and power supply
it can store energy with a little or kill energy with a lot
so the bird has a double v
two wings but unlike the fish
its radiant absorber is not the water through
the gills but the first side off each wing
this is double proportion to its tail
which is 2-1 all energy on earth
negative energy is a illusion there is no negative
only half the power of the positive
then the v of the wings allows the bird
steer but what must be over looked is there has to
be a percentage of air that goes thru the featers
essential the gills of the fish this is why its very critical
birds are clean if the air only went
over and under it could only fly in wind
but birds fly in frequency not wind
now they do use wind but they can fly in no wind due to the tuning of the frequency between the feathers big birds fly slow
low frequency humming birds fly fast high frequency
so you see birds are a refined fish
in physics and when the frequency of the air thru the feathers is understood
or water thru gills we dont need fuel
Low-Q
Some thoughts:
You cannot go faster than light. Matter are energy, so if this matter are travelling at the speed of light, matter will be transformed to light. That is the reason why nothing can travel faster than light....The speed of light are limited to the time through space. Maybe gravity are a consequence of this time and constant speed of light. The slower the light, or any form of electromagnetic energy, can pass through an object, the greater the gravity are.... just some thoughts.
cletushowell
Your correct your not traviling in the light
wave frequency your traveling in frequency magnified
now in order to magnify the frequency
enough to warp you have to back the frequency
up over a period of time then discharge it
at one layering the space time
light double light tripple light you tripple light
double light single light
so your creating the space time but the key is to do this you must
oscilate the time back thru itself you or the craft
like the fish gill the time is the water its going
thru the fish the tail directs the oscilation
so speed of light magnifyes energy this is why marco says you can sit on the sun and drink ice tea its not a absorber or conductor
but both its conducting the absorbed energy
back to the conductor not back to space time
sm0ky2
light can only travel at the speed of light (or slower) because that is the speed at which light propegates through the universe.
the aether
einstein was unable to detect this, because of fundemental assumptions in his flawed theory.
When you effectively remove the eather-mesh from a portion of space, light traveling through it ceases to  "be light". the observation of 'light' is the effect of the energy traveling through the aether, which occurs at a constant rate, unless otherwise affected.
With no aetheric-field present, things have no physical restriction on velocity. The maximum velocity anything can travel, unrestricted, is somewhere just shy of instananeous travel.
this can be demonstrated by removing the aetheric-field and replacing it with an oriented magnetic one. Electricity can then be channelled through this field at velocities exceeding the accepted value of c  .  The only issues of "time" that occur from this, are timing issues in the equipment to handle and process such an event.
The problem with creating such a field around your spaceship and traveling through space, is that you wont be able to "see" what you're flying into.
light outside your little field-bubble would still travel at the speed of light,you would be passed it before you ever saw it there.
so it would be wise to ensure you have a clear path before going on that kind of journey.
It is theorized that "time" itself is different inside such an eatheric distortion, so your ship and crew may reemerge into a much older universe than you left, though it would seem like a fast trip to you.
For example:
if you were to travel at twice the speed of light, (Warp II)
to us here on earth:
you would appear to have travelled two light-years in one year.
But in your spaceship, that may have only taken you a few minutes.
