a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
Rosemary Ainslie
Quote from: sparks on August 30, 2010, 09:16:13 PM
   @ all
     We are down wind of Leo and the two of us are heading towards a supercluster of galaxies beyond what is known as the Great Attractor.  The gravity from this dense cluster of matter is pulling the entire Milkyway there.  Since gravity is pretty quick way faster than the speed of light we can assume that this cluster of galaxies is still there even though slowass light is taking forever to get here.  The young cluster of galaxies we are seeing most probably exist as a super blackhole by now long ago gobbling up the hot matter and cooling it down considerably.  Gravity is an accelerating force.  It accelerates stuff aound here a 32feet per second unless you take the moon into account which slows this acceleration down.  Gravity like movement is a relative thing.  The more mass in a given field the more gravity.  To counter all this mother nature in all her wisdom produced antigravity.  This manifests in like charges being repelled.  There is no positive and negative there is just more or less electricity in a substance. The proton is assigned a positive charge.  Why because it has less mass density.  It is quite large compared to the electron yet it has equal charge effect.  This is because it has less mass density.  If it had the same mass density as an electron it would have the same charge state as an electron and would repel the electron.   A blackhole does not gobble up another blackhole.  We see a blackhole gobbling up the less dense matter surrounding the blackhole at the center of each and every star but blackholes are relavent to blackholes.  Once they have stripped the hot stuff it leaves the core of the star which is at the same mass density as the big black hole.  The two black holes then begin to accelerate away from each other on their way to creating new galaxies somewhere else in time and space.  There has to be antigravity or the big bang has to be repeating itself over and over and over again changing just a little bit every time.  Imploding and exploding so damn fast that all we see is minute changes dictated by whatever force is controlling the whole creator frequency.  Of the two sceanarios I would go with antigravity.  At least on the 7th day when the creator takes a snooze.
Wow sparks.  I'm blown away by all this vision.  Very nice indeed.
Rosemary
cletushowell
Understanding black hole requires you to understand
your looking at a optical illusion
the inside ring equals the outside ring
you can demonstrate this a couple ways
put a little dirt in some water the shine the magnifying glass in it
you see a hour glasd in the dirts particles
now understand a pipe what does it look like from
a distance one ring the first ring is bigger
the the other the hole thru the pipe looks smaller
but its not smaller its the same size you just see
one side so your always either seeing
one half the hour glass or a pipe
now the black hoke can do virtualy anything its not stuck to your laws
just like gravity can change betwen
more frequency more temperature or magnetism
and all three no matter the combination
give you gravity you can have a little frequency
a little magnetism and a lot of temperature change and
you have gravity now if you find the calculation
for the firmula for all three like a=b= c= gravity
then we can overcome any temperature
any magnetism any frequency all the time perfectly
so call this the howell equation of gravity
gravity = f+t+m
any known two give you the third
so the easiest is the temperature
for lift over weight
the amount of magnetism to add to the temperature to abtain
the rest then frequency you will have soon
with daves device suspend a ballon add a metal plate
see how much magnetism to lift and drop it
then use lids or bendin or daves device to add frequency to lift
compute the calculations you will have
the answer to exact specific gravity of anything.
Rosemary Ainslie
Dear Cletus,
I have finally 'succombed' and decided to answer your extraordinary post.  This time mainly because I've been rolling with laughter.  I LOVED the howell equation but you need to define your terms.  And I'm delighted to discover that anyone at all can find gravity variable according to temperature.  It's like science according to Lewis Carroll - an Alice in Wonderland series of weird physics .  It usually gives me a headache to try and read your posts.  I now realise that you're just offering us all a little light relief from reality.  Or rather a lot of light relief from reality.  I'm sure it's appreciated.  But frankly I'd prefer smaller doses.   ;D
Regards,
Rosemary
for those who may have missed it here it is again
gravity = f+t+m
Got to love it.  All that freedom of thought and freedom of expression.  And an extraordinary license with logic.   :o ::)  LOL   ;D ;D ;D
sparks
   A blackholes gravity and the gravity of the great attractor and the gravity of the bird up in the palm tree outside all intermingle and are felt from one end of this Universe to the other.  Can you stop gravity with anything.  Can you shield it.  The only thing you can do is increase your mass density until you are of equal or greater density than the mass density field you are trying to be relavent to.  Frequency is time dependent.  Field changes measured by a fixed observer over a period of time.  But time is not a constant it is relative.  Time doe not appear to pass identically for observers in different inertial frames.  It has been proven many times by clocks on jets and spacecraft.  The more mass density the slower time appears to pass.  If we could approach a planet 5 or 6 light years away at speeds approaching that of light with a telescope on board to watch what was going on with the planet, as we moved towards it everything on the planet would start to happen faster and faster.  When you move through the spacetime continuom you move through space and time.  We would see what is occuring on the planet which would appear to them like taking thousands of years happening in seconds on board the craft.  The planet would age at an accelerated rate.  Say now we slow the ship down just a light year from the planet and lock in at its velocity.  We would see their past.  If we set off a lazer beacon it will take a year for this beacon to reach them.  If we send out a gravity tug it will reach them immediately.  Say we can communicate in Universal time with this planet through gravity transmission.  We could tell the citizens of the planet we will be there in a year.  By the way we know all of your ancient past and have it recorded here on board.  Then you start sending them pictures of stupid shit they did.  You also predict that one year from now you will start seeing holographic images appearing in your skies.  (The light lazer you sent out)  You put on a regular light show for em.  Then you tell them that we are coming so get your shit together or were going to take care of business when we get there.  Time is not a constant it is totally dependent on the condition of the observer.  Say we get to the planet enact some laws and order topple the slavers and give them some technology maybe even mate with some good lookers.  Now we dont want to spend the rest of eternity amongst the barbarians so we jump aboard the craft and bring it up to high speed.  We have lunch and a nap then we slow down and take a look at what the smart monkeys are doing.  A hundred years have passed for them a day for us.  There doing the same stupid shit they were doing before lunch.  We lived for 100 of their years while it was only a day of ours.  We could do this for tens of thousands of years just popping in now and again to cleanup the zoo.  Meanwhile the folks at home want to know what is taking us so long at work.  We explain.  Kids are a pain in the butt sometimes we understand.  Dont forget to bring us some souveniers.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Rosemary Ainslie
sparky?  I wonder if you shouldn't be writing scripts for Dr Who.  Definitely some frustrated literary talents there is my take.
Nice reading.
Regards,
Rosemary
