a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
david lambright
hope....i must work today, when i return today i will post the dimensions again...have you seen the step by step videos?here is the link    http://www.youtube.com/watch?v=Jjh5OE6yerk     there are 5 videos.....if you want to see the effect, you can construct my other device, an aluminum tube filled with iron oxide and energized like Eds PMH....the oxide core device is easier and less expensive to construct....thanks for your interest......and rosemary, what do you think of the progress so far?....we are getting closer to the answers that we seek.....do you think we are ready to move this thread out of the half baked ideas yet?....thanks rose for having believed in me....you are my friend!....david
Hope
Hi David,   Just the copper wire info   winds   battery volt/amps and how you make it lock magnetically  an to which poles?    OK please bend your ears a second,  today while working on this build we discovered that even in open air the dust from splitting the pipe made the fillings in our teeth galvanic   or maybe was splitting that long cavity did something.... careful .     BEST suggestion since the cutting is very slow and will take hrs,   just have it cut by someone setup for it,  it will take them minutes compared to hours and they will know how to safely handle that hard pipe.   I second your suggestion David to have a metal worker or pipe shop make your pipe into ready to use pieces. So far after 3 hrs of cutting we are half way through making the metal parts.   Will keep you informed on progress.  And a pipe (tubing cutter) cutter is great making the sections.
sm0ky2
yeah, im not sure how to tackle that part...
i have a nice piece of pipe, and i bought a cheap cutting board to slice a circle out of, but i dont have a saw like Dave has.,
started to tackle it with a hack-saw, but thats kind of loud here at night, so i'll get back at it when i get some "daytime" freetime.
i have a Diamond-Carbide high-speed cutting bit for my Dremmell
i may see how that goes ( after suiting up in the appropriate safety equipment).  I can easily chop a screw or nail in half with that bit, so it should cut the pipe no problem, as long as it doesnt dull it i guess.... if not i'll just man-handle it with the hacksaw.
my first thought was to search for some "slit pipe", or half-round
but i couldn't find anything like that at the hardware store.
so i just went with the fence-post like Dave used but mine is a tad smaller diameter.
i'll post on how it progresses
sm0ky2
charge an object, piece of hair, styrofoam
and move it to the center of the vortex
sm0ky2
a charged particle gets sucked straight down into the center, superfast, and gently floats back up around the outside, and back in again..
why does $%^!* radiate like heat??!?!??
wtf is this?
Lambright Radiation
[edit:   i took it apart. I think we should probably figure out more about what this is, or at least where it sits frequency-wise, before we continue playig with it in our homes....]
