a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
nievesoliveras
I have been having problems with the elctricity service and the internet.
The electricity goes out on the block and when it comes back I have troubles getting on the internet.
Quote from: david lambright on September 02, 2010, 03:28:44 PM
jesus, thank you!.....could you describe what you see?....and smokey2, i would like to copy your version of the device...it seems to have a good output of this radiation...thanks everyone for your help....david
I see a very light film like the one that is made from soap water on a ring. But if I get closer to the device, it dissappear.
Quote from: sm0ky2 on September 02, 2010, 05:11:27 PM
@ Jesus,
thank you. that's the confirmation i was looking for.
The vibration stops when the needle is aligned with the ring magnetic field.
Jesus
sm0ky2
Quote from: void109 on September 03, 2010, 12:39:28 PM
tookferrite cores and cut them in half with a diamond wheel.  I arranged the remaining 10 half circles in the typical arrangement, wrapped coil around one of them and pulsed it to see if I could get it to lock.
No dice, they would forcefully join during the pulse, but completely released afterward every time.
These cores are made with a filler-material. the material which induces a field is seperated by "glue" basically.. i dont think they will work for what we are trying to do.
I also made a PMH with a U shaped threaded bolt from home depot, and put a 0.5" x 4" steel bar across it and locked it.  Then placed it in water as I've seen others do and froze it.  I didn't see any anomalies as others had.  The PMH effect was there to be sure.
screw pieces down onto the bolt theads
     (may have to redo the wires)
But you can modify the normal PMH into what Dave is doing.
like "wings" on the U-Bolt.
Do you think it is just the case that when we pulse the PMH it is aligning all of the atomic dipoles, and once oriented, they hold each other in place?  Then when you quickly remove the bar, it is just the dipoles 'relaxing', or spinning to a rest orientation, and its this relaxation that is inducing current in a pickup coil?  While this wouldn't explain any of the effects being discussed here, in this description there isnt anything 'flowing' around the flux path, it would just be the dipoles locked in place.
Yes and no,.  When you say "locking the di-poles", what you are really talking about is orienting the (average) spin of the electron in a vector which produces the N and S dipole-field in a constant direction.
"polarizing" the metal.   the same thing that happens when you stick a magnet onto it. sort of...
With a strong magnet touching the metal, its the field from the magnet that is dispursed through the material.
With what WE are doing,. its the field from the material itself, resonating throughout it, in a magnetic vectoral path.
thats why i drew those pictures a few pages back, to show the "apparent" motion of the curent, but its really just staying in one place. like the poeple doing "the wave" in a stadium.
You are right about the relaxation producing the "pick-up" coil response. that's a portion remaining from the input power, after all losses. Which is irrespective of Dave's effect.
However,. since the metal is being magnetically induced, constantly... it amplifies the atomic signal, times x # of atoms.
Theres really only two basic differences between this thing here, and lets say...  Plutonium-238
1) this resonates at a MUCH lower frequency.
and 2) We can turn this OFF and ON.
Mathematically the effects are identicle.
david lambright
void...i never was able to get a lock on the u shaped ferrite unless i used a steel keeper[i did make a video]...the ferro fluid core works well but what i was planning was a glass torus, hollow, filled with FF, and wrapped with a rodin coil.....a U shaped steel with the ends 1/4" apart, the ends put into the FF and energized, the FF completes the circle and will stay there when it is removed from the FF....if that makes any sense.....as we all know by now, these effects are not very easy to image, let alone see it, but they ARE there!....anyway, i must go to the post office for a minute, but i will be back soon....david
cletushowell
Wow ok guys and girls we have odviously got
more brains on one thread then probly anywhere
but please spare us all the science theories
and cut the words to basics magnetism
direction light frequency things me and dave
relate to
speed of light is variable so there so reason to bring it up
space time continum all this stuf is
like static to my brain its pointles confusing
please try to do best you can to not
clash in a science debate by using words and terms
not defined by a meaning or use its a language of nothing
apple relates to a apple
the earth power grid is a relation of the water
storage and the cuts in earth
if you have a crack in a car head
when magnitised it attracts a poweder
earth attracts water to the cracks
the river its very complicated but the river conducts
the rainbow the crack in the magnetic feild
of earth making it a perfect polished crystal like tesla said
im working on levitating the rock
for you i did levitate the first portion of my testing
of what i guess is the joe cell using aluminum and
copper wish me luck on my rock it does spin the magnets the same as your stating on the string
cletushowell
Im sorry i cant see the
name neivo soleous I know i messed that up
your power grid problems can be a couple things first check your experiments
antennas coils rocks batteries anthing you have hooked up
your possible hitting the black hole energy if you are your reversing the grid
you need to find this out quick
or your going to have a mess yoir computer
is getting interupted by the magnetic fields thats why im pretty shure its you not the grid some thing you have done created a giant magnetic feild
this is how i wiped eveything find your groubd rod
and soak the shit out of it with water
or your going to have a really big mess
and health problems once it starts funneling frequency
its radiating the rock that radiation
interferes with everything soubds to me like you have started or are in the proccess of starting that check your
wireing figure out where your frequency is coming into
and going to your ground your essentialy sending
power to the ground the ac becomes the ground
sucks for you because its not measurable but it goes backwards thru the first transformer to the second where the hf high voltage
is converted to energy to the next grid  i dont know how to do
that on a small scale im working on it those smart metters
have a computer chip inbetween the 240 volts
the problem millions if ca have is magnetic feilds interfere with those chips
like the power grid pulse solar flares do it on a massive scale
