a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
cletushowell
Ill search tomas brown you search
uss liberty youll see the malfuntioning
invisible ship was going invisible and
not invisible make israel shoot at it but the first gun fire was static
and i can prove that in my testing in fact when i can load my next round of videos your going get a buch cool stuff
heres the list
I bent light
i expanded a 2 litter and shrank it perfectly
i polorised the rock made it a heat producing
water boiling machine
I developed this super fast aluminum
oxidizeing whatever that turns aluminum can to a paper
its making the elecrrical current some kind of
acid removing or giving energy to the aluminum
i did a awesome antigravity demonstration
by reversing the last aluminum can putting the rod copper rod in it
and if it had polarity like the hovercraft would lift in air
i did alot work trying hard to undertand the
ph of the limestone coral how this aluminum
gas can becoming out the coral like the hovercraft
making it the hydrogen type generating
system using the ph to make gas
now i know what your thinking why is ph important ph is polarity
salts are positive acids are - or other way around forgive me
so by knowing the ph we can offset the
polarity with energy this gets conplicated with no coral book
and different rocks and not even limestone
but im still close to lifting it it may not be how he did it
but i got a pretty good ubderstanding of how he did it and
im pretty shure im going to have to compensate for
different rock minerals and structures
mine arnt porus so my gas does bubble but not like his
would thru coral i polorised the rock with antenna ballanced it
cut it removed the radiation
charged it then added salt heated it cooled it adding salt each time where does all that salt go does salt evaporate
seriousthere was a lot if salt like
a handfull went into this rock like the size of my finger
i didnt think salt could evaporate or turn to gas
maybee im wrong but that 2 litter proved a lot
it proved eartg is expanding due to energy building
if you remove the water and energy from earth all the land mass shrinks in exact form so it would all go back to its original state
how fast xan eartg discharge i dont think you want to know that answer
lets just say it can be very fast the speed of radiation
the speed at which it charges is not the speed it discharges
remember whoa to the earth im going to say 7 days
just because it was created in seven well six
but 6 is really 3 now were talking
because the evening and the night were the first day
so 3 days on our callender three square waves hit
the bend seven the sevent part of wave six sides to the box three
days 2 steps forward one step
back 1 doubled is 2 two doubled is 4 i step back is three
4 doubled is 8 1 step backs is 7 8 doubled is 16 sweet 16
16=7
oh stone soup i got my carrots
theres a antioxidant in carrots may improve the air batterys
and the lead acid dc problems
charging with moray cell
im going put them in the water in morning
and see what it does wish me luck
Hope
Hello All,   Long day but great weather here.
The discussion changes quit a bit here.   http://en.wikipedia.org/wiki/Ark_of_the_Covenant will give you some information.    When it was housed it was in a Tabernacle which was built in a special way.  It had a very unique foundation system http://en.wikipedia.org/wiki/Tabernacle this may have been the arc's recharge collector.  Also it says something interesting about a crown of gold or ring AROUND the Arc (like a crown seems to mean to me at the top) and near the top perhaps suspended who knows how, i don't.    How do you think they knew the arc was recharged?   And why NEVER remove the gold covered slats (carrying handles?) but even more how was the arc used.
Cletus has an idea I bet since he discharged into the surroundings.   Maybe he can tell you of the total reported and known other items effected.    Dave where did the tubing come from you used.   I am pretty much stuck buying on the island for this next week.   I found a toilet water line metal flex braided I could get a steel coupling and remove the washer that exists in only one end, but the material is steel I think not aluminum .  AND DID YOU ALL understand that post about the device spinning when lock with the 3 parallel coils.  Spinning without stopping??? Is this was he meant??  Help me out here,   attach an efficient motor/generator design and OU is near or achieved.    Excellent use of the colors  this 3 - 6 - 9 Smoky2 they are angles or phases.  If we need something to react with each element emits/produces/collects wavelengths (radiant energy). Our eyes see light because it is build into us, developed because of its availability was the most constant, thus we sighted use this sense the most.   So if we were around another source and that source was the most available then we may have developed a sight based upon say the darkness? So it is a matter of perspective of your total environment of what you can see.  The importance being these OTHER types of light may be harmonics or subs of a central light wave that sets the frequencies of all other "light type wavelengths". The helix is odd to me, truly it is beautiful but seems vacant to me of a second helix at 90 and 180 degrees.    Man am I going to get trashed for saying this.  But it always seemed like we are missing some pairs to the current movement. What did you say Cletus,  3 things mattered.  Maybe by including them all in a helix type model we can see their relationships better.  I am very CAD less at this time (any freeware ones?)  Can some one CAD out a helix type model of the three variables and pairs in Cletus's theory? Edited
cletushowell
Oh the salt created a underwater type plasma in the water
im shure someone cooker then me has done this before
but it was cool for me to see i made a light bulb out salt pile that was cool
i shook the whole house with this water plasma it made the water vibrate
like you see when people put water on a speaker
and i meant to say the 2 litter shrank exactly half its original size that was a trip but very cool like all these faces my uncle has pictures of in rocks coukd been like all shrunk the last energy discharge
seriouslyif you understand expanding specific gravity and contracting it
i expanded the 2 litter and contracted it with a water plasma of
h20 aluminum salt 120 volts copper boiling points a
over flow pan i created a minuture pressure
makers let the pressure build up the released the cap
it was pretty dumb and dangerous
living life on the edge dam i got shocked a bunxh today usualy about 10 times a day but today was a kicker man
like every wire was just im the way of my hand
after my hands were wet and playing with that salt shit that was a good one
still nothing like hitting that 220
or the neon liscense plate from pepboys that dam thing jumped about 6 inches to my finger serioisly is the bulb on a neon
just for safety cn those jump the distance with no bulb
isnt that what makes the tesla coil sparks
im not cool enough to have a toy like a musical tesla coil
ok well good night oh the limestone has argon in it from what i read
maybey thats iteresting but argon is heavyeir then air i thought huh
cletushowell
Hope you didnt get the key did you
emaill me I send you the the eye ball
its so cool think of it as light going in
and bouncing and the going to the retina but the eyes
pick up the bouce in the star
ch@helpuflip.com
cletushowell
I cant tell you why but some time last night
that aluminum green stuff floated in that
cup its dropping like snow and
covered the rock so some how some way
that stuff lifted last night now its a aluminum oxide i beleive
but it green like moss its the key to everything
i know it is because God told me when he walked on
water that he walked on this stuff looked like lilly
pads I saw it all in a dream the wind changing the frequency
of the salt to the green now i have salt and
green floating stuff i really dont know what to do
i feel all the answers are here in front my face
and if i cant see them what good is more testing
some times i wake up with the answer some times i wake up with the question that answers the problem today i woke up
with a question if the fluid is chasing the north and the south
like ed says like i did how does that work
its a circle clockwise dont ask me why it circles clockwise
thats the ion flow the north chases the south
my phone cannot demostrate it in a video
its poor quality the bubbles and ion flow
the green stuff really makes it more
visible when i did the coral castle codes i should lifted this rock i regret it now
it had something to do with edd did it the very hard way
and a coil from each of those generating wheels
in perticular order lined the power direction
from the helix outside to the north chasing the south
it was 10,2,7 i have forgot it all
im sorry i dont understand how i can forget something so important
must be the goverment again im going to try to go thru my
notes i left on the castle video if there still there and see if i can remember
it im so stupid i had no clue it tied everthing together
i thought if i released it would just ruin the mystery
and make the castle no interest plus the radiation was dangerous  i didnt realize it ties everything to the energy
I guess if I dont figure it out again you can list this as my biggest mistake.
