a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
david lambright
hi hope...i dont think that plywood, hdpe, matters...i made a small, 2" diameter, model that has no center but still works....i was thinking that this radiation/device wants to seek equilibrium ...on Eds device, the engine block and on the top the chains and pulleys, looks like they might have been equal in weight, but not symmetrical or equally spaced above and below the device...i think that this flow wants to be at the center of mass, what did ED say about putting the wire IN the metal?...i also think ED used his device to spin this energy/radiation into a vortex that tried to pull down on the overhanging mass of chains etc.......this radiation is energetic and has a motive force, that is gravitational in nature, i believe, and ED used this to build his castle....a gold ring tied to a string and held around my device has some odd effects.....i believe that metals act like filters allow only certain waves to pass, like we use lead to shield....i filled the cavities with foil and it seemed like the effects were a little different...i am trying to get bismuth in a tube or hollow toroid to make one of my oxide core devices....the aluminum ones act like lenses....i have been working on no glass/media, just air/space lensing, using these devices...david
Hope
After this build is up and working I think i will try to make one out of PVC and face it with aluminum foil and place foil above and below it as metal mass (filter).  I too believe the different elements all act as "filters" (collectors) of separate or multiple individual wavelengths.   I know of no way to "stack" magnetic charges,  maybe Ed Leeds.. did.   It would only be a matter of matching the charge of the earth back upon the item he wished to move (like charges repel) possibly.   I hope this energy fluid IS the magnetic charge becoming dense enough to be seen.   It would certainly open an new field of science.
cletushowell
dave I didnt read everything but you are awesome your next step is discharging the energy
thats the key you polorised the aluminum the rocks I havent seen but i did that with a antenna hung the rock but take the store magnetic energy back to below it flipping the poles taking th eenergy from the north pole to the south pole the amount you can store and the amount you can remove is the amount you can lift
you real close dave.
sm0ky2
@ Hope
i can confirm what Dave is saying,
    The test-version i built the other night was just sheet-metal bent into (almost) cylinders with nothin in the middle, i useda rubberband to keep them together until i charged it,
then took the rubberband off to see that they were actually magnetically linked to each other. thats how i knew it was "on".
once i pulled it apart, the pieces were no longer magnetized
Just like the PMH
the insulator dave uses (HDPE or whatever) this is much different than wood.
most plastics seem to have very little attraction to the energy.
but minerals and organic substances attract it very well.
look at Daves videos when he plays with wood.
i think using a wooden center might create a short-cut path for the energy to flow through.thats just my theory though.
i know having a center to the device enables you to make it spin.
but what im interested in are its solid-state applications.
like a Zero-Point module. athough that cannot be used to properly explain this device, because according to ZPE theory, at a temperature of 0 Kelvin, this device would stop emmiting energy alltogether.
So, from a scientific standpoint, Lambright Radiation will have to be explained by an entirely new theorem. One which should undoubetdly include Ed's model of Magnetic Current.
Hope
Maybe by charging a capacitor and then letting the fluid energy pour over ONE lead the charge on the cap may gain or lose potential.  This may give us a hint to its polarity and if it has electrical potential at all.   I am still building a stand  (getting the fan off this bad alternator is harder than I thought).
