a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
Rosemary Ainslie
Quote from: david lambright on October 11, 2010, 09:21:55 PM
the 2 oc devices to seem repel each other and this effect seems to grow .....thereis a definite pulsing of this field...now i realise how this next part is going sound....while expirementing with this effect, it seemed as though parts of my devices got to looking ethery...like trying to go transparent?.....my large OC PMH really has good output in the visible range and with the flow against each other i am seeing more color in the field...david
Dave - that's jolly interesting.  Can you give us a video of this?
Kindest regards,
Rosie
david lambright
rose....i will try and get some better video.....also rose yourOC device is ready to mail!...i just need an address.....i have been using your device to make sure it has a good output......i forget who-all i promised an OC device...i will have to go back through and look.....thanks everyone....david
david lambright
Quote from: sm0ky2 on August 26, 2010, 09:59:30 AM
@ Dave
the ferrofluid gives me some ideas..
you could put it into a clear plastic tube
like those glow-necklaces.
be a trick to get it 100% full, but once you do and seal it up,
you could energize it, and have a liquid PMH
and see if there was any motion of the fluid.
or like i mentiond earlier, a solar-cell that can pick up IR light would be a real simple test that would clarify 99% of our questions.
If you could pull that off, and definitively prove the radiating energy, they'd put yur name in the history books right next to Rontgen, Becquerel, or Marie Curie herself.
..........i have made a ferro fluid core PMH but i cannot detect any movement of the fluid...i also put powdered oxide into a clear tube and was able to energize it.....the oxide was black when i put it into the tube but after i energized it, it has taken on a grey/purple color?.....smokey2......i ask for your help in this matter......you are so smart when it comes to this....your insight is brilliant.......david
david lambright
hi...did i do something to offend any one on this thread?....i am so sorry if i did.....i know i have been slow but i do have 3 OC devices ready....rose?....anyway thanks for your intrest in this...david
Rosemary Ainslie
Dave?  I don't think anyone's offended.  My problem is that I'm too thinly spread - and I really need to try and concentrate on less variety of interests and, hopefully do more - so to speak.  But your work is much appreciated.  There is the problem that the evidence is tenuous and not measurable.  But I think what you've disclosed is that there's a definite interaction with light and what may be an electric field or a magnetic field or both.  Just not sure.  But press on here Dave.  All efforts to get to this elusive energy source is always much appreciated.  I must personally apologise that I really need to concentrate better on my own thread and, hopefully, on Laser's.  It's getting to that time when my own time will be pretty well fully accounted for.  As it is the days are a little bit too short.
And many thanks for the HUGE efforts you've expended.
Kindest regards,
Rosie
