a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
nightlife
 LOL, you guys crack me up. What you all are seeing is a twisting energy field and do to the fact that everything is nothing more then a energy, you will expirience such sights as that when moving things around or other energy is brought in the picture. Hutchinson and the Narrows should remind you of such effects.
I have been trying to tell everyone this but no one seems to understand. Nothing is solid and everything is nothing more then a energy field. Answer these questions.
How can we see things?
How can we feel things?
How can we hear things?
How can we smell things?
Once you have been able to answer those questions properly, you should then understand what everything is. Once we realise what everything really is, we can then start moving forward trying to find ways to utilize all the energy around us. One problem we have is greed. Everything is alive and life must consume life to survive. The more energy we consume, the more life we consume which effects our generations to come. We are going to screw around and mess everything up at the rate we are going. We must be carefull becuase we could possibly create an energy field that may alter all the energy fields that we have today. Take heed to this, we are an energy field too.
infringer
I think that it is unlikely that we will kill all human life resonance for a human being is different from person to person we are complex beings by nature while we are sometimes persuaded by suggestive thought others may not be and this is one thought that I chose not to agree with.
-infringer-
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
infringer
Quote from: david lambright on February 21, 2011, 11:36:41 AM
hi everyone
i just have to say, after reading all you guys posts, you guys are very smart and have really got this thread moving in a good direction, [you guys have brains, i HAD one, once] anyway i thank you all for your help with this...i have to agree with farmhand, i cannot claim any thing as my own, i am just trying to help bring it together....this all started a couple years ago ,[actually when i was 5] i was messing around with magnet motor designs and then i remembered Ed...a lot of years ago i had our library get an original copy of Magnetic Current....it was small so i copied all the pages...i remember it took a week for our library to get it..i think i was in my late 20s so around 20 years ago...the words he used, "Perpetual Motion Holder" always caught my attention..so a couple years ago, i made my first PMH, with a 16d nail, bent into a U about an inch tall..i used wire from a transformer and a 9v battery to energize .. i made more Us [no coil] and found i could link a a few them using just the one small coil [5 or 6 in a circle] it was then i realized Eds flywheel IS a PMH....i started to experiment with toroid shapes, small at first and with a 1/3 section cut out [2 junctions] and two coils...i like the single junction ring because it would clang when it was energized ...i found that metals seemed to behave strangely, especially a ring shape spinning...i tried different coil configurations/ sizes/wire materials etc...i kept thinking i saw the wires move, so i marked their positions..they were NOT moving...there was something distorting the image....what was this?..WHY was this?...i had to find out..i set about making the distortion more "visible" so that i might understand it better...i found that not just steel or iron would work but ferrite/Fe3o4 oxide will work BETTER for my purposes.....i have made one out of ferro fluid and one using mercury as the core..i found that quartz and other crystal seemed to reflect or absorb this energy..i had to build something similar to Eds, to see if the field was stronger in that type of design..i did, it was..while working with that configuration, i kept feeling like a pulling/attraction at the poles and a pushing/repulsion at the plane..i could see this energy and it is exactly a double helix spiral form!. could it be that this energy i was seeing, was in fact the same type of energy Ed used at coral castle?..i had to find out....i went over everything i could find about Ed and his castle..in some of his photos there is to me, evidence of this energy being used..the shadows in some of the photos looked to me like they were distorted, as if by a heat type wave, when the rest of the photo was in focus...the energy i was seeing was exactly that form!..like a mirage ...this was starting to make sense to me now..Ed told us that the energy he used was NOT electricity or magnetism, but something different, deeper than those forces...a SOUND BASE to start from...i KNOW that this visible distortion, is just a part of this energy...when i watch videos now, like Hutchinson's, i can see the same distortion happening...i am compiling a list of videos that i can see the distortions in....
I will give you an easy way to test this theory and prove it.
Build 20 of these rings.
Stack them like pancakes creating a tube.
Build 20 of these rings with no magnetic properties just hallow rings and stack them.
Get two super balls with the same weight and size.
Build two sensors that will trigger a led to light up when hit.
Place these sensors in the middle at the bottom of the stack.
Borrow a high speed camera and see if gravity was at all distorted by dropping both balls from the same height at the same time. See which one lands first repeat the experiment numerous times to assure find is correct and show precise measuring to display the heights are equal.
If it is something worth investigating people will take this further.
Simple...
Me personally I see no distortion that is out of the ordinary for cameras of all types I just see a ring. But it would be easy to prove your theories or disprove them!
"It is not the spoon that bends Neo it is your mind." famous quote from the matrix.
As to your response for needing a special camera to view your possible effect:
Run an add in the classifieds until you get one that would be my best guess otherwise contact your local collage and ask if they could film it for you. Like I said if you believe there is any kind of wild anti gravity effect... I gave you a simple test.
-infringer-
nightlife
Quote from: infringer on June 10, 2011, 10:26:08 PM
-infringer-
There isn't enough DNA differences among the human race to justify there being multiple races amung the human race. That speaks for its self.
Now we have to think about the basic energy fields such as the basic elements. The atom is a energy field just as each element that makes up an atom is. If we were to alter one of the elements that make up a atom and it caused a chain reaction that altered all of those like elements, I would bet it would end life as we know it.
david lambright
ferro fluid + magnet + saturation
if i suspend a 1/2" cylinder neo magnet by a string and dip it into ferro fluid, i can saturate it to the point that it will not hold any more. add a drop and a drop will fall off, gravity having full effect. OK, now if i add a stack of 10 -1/8" cylinder neo magnets, it is like having a stream, leading to a pond. the small magnets allow the fluid to flow UP to the larger one. the same saturation occurs, if i add a drop, a drop flows off, AND if i use an eye dropper, and pull a drop off, a drop will flow up to replace it. because of this fact, a siphon CAN be started and a continuous flow will take place in the tube. a porous material like earth will do the same thing with water. if you had a large container with a cone shaped island, with water in it, added water till there is some standing in the low end, you could make a well at the highest point. the water level in the well will be higher than at the outer water level, so a slow siphon could be made there too. a valve could be used to adjust the flow out so as not to exceed the wells refill rate, making a continuous flow. this does not bother any physical laws, but rather embraces them. this would mean in a closed system [no evaporation], this system should keep a constant flow forever, gravity being the engine. a continuous flow of water through a tube. natures wheelwork. we know how a water table will raise water, and the physics of a siphon to make it flow in a tube, downward. the only thing is there must be a starting action, but it will flow as long as there is water in system....david.
