Please BAN and remove all posts from user cletushowell
Started by FatChance!!!, August 17, 2010, 07:50:53 AM
cletushowell
Heres your matrix
of 42 I already Gave it to you
its the string theory formula
I took the basic polarity and gave them
to you but You dont get it
++-- =.    2
++++=.  4
then you see the right side is
2 the left side i 1
if You only knew what this is then
you Would understand
there not just numbers i picked these were released
well before you ever posted 42
in fact I dont even know why 42 is important
but its not just your post its everything
but its really 24 not shure why you say 42
but if you email me ch@helpuflip.com
ill answer that for you
sm0ky2
just as 7 is 1
3 is also 9
i can show you
3 = 21
7 = 1
2 + 7 = 9
so 3 is 3 and 9
45 is just a higher octave of the same signal.
but if 3 is 9, which is also 18
then 369 = 18 and 69
18 divided by 69  = the 1/4 wave
This is the basic foundation of the odd-number portion of the theorem. even numbers represent the full wave. (real numbers)
odd numbers represent fractions of the wave, which can sometimes result in imaginary numbers. This simply coresponds to negative values of the electrical potential moment.
meaning the underside of the wave, when we examine it on a 2-d horizontal plane, as we often do to, describe wave-function.
sm0ky2
I'll explain the difference between the 24 and 42
This is because of your conception of the + and -
         we measure it backwards. its really - and +
thus it should be 42
put the matrix up in the air in front of you and walk around to the other side.
dllabarre
@Cletus
I'm stuck!
Please respond to my private message i sent you.
Don L
cletushowell
The 369 is only 360 degrees
it only circles earth
200,000 -56,000=144,000
56,000/9/6/3= 1234567910 no 8
this is your one side of infinity
but infinity is 3 loops will be 5
but not yet
144,000 is your axis the middle loop
144,000/9/6/3 is your third loop of power
the8888888
144,000 is pie its exact middle
when you the zeros are your three loops
computations  the 144 adds to 9
99.9 percent of people will never get this
the path is straight and narrow meaning
you have to set aside everything you think
you know to understand the truth is not taught
in Highschool
