Ok help me out how do you build 120 volt 100 amp battery
Started by cletushowell, August 22, 2010, 09:34:49 PM
MrMag
You may not be a fucking idiot, but you sure sound like one.
How do you expect people to take you serious with all the fuck this, fuck that language.
You need to show a little courtesy and intelligence if you want people to take you serious.
As far as looking for an AC battery, they don't exist. Just look around at any device that stores energy.
Solar panel systems, windmills, UPS's, they all use DC batteries for storage.
If you want to store your energy, you need to convert your AC into DC and store it in a battery and then
run it through an inverter to change it back to AC.
I know I'm not the first to tell you this. But you've asked, and we're telling you.
If you want to listen, well, that's up to you.
Pirate88179
Cletus:
I would suggest listening to MrMag.  He is trying to help you.  He knows what he is talking about.
I realize that you are taking some abuse here on the forum but, if you look at the average post, and then one of yours, well, you might see an explanation for that.  A lot of folks here have problems, everyone does in one way or another.  There are a lot of good folks here that will not abuse you, and are trying to help you, even though your posts do not seem to reflect any appreciation for these efforts.
It may be that is because you are used to the abuse your posts seem to attract.  I can understand that.  Just know that there are some good folks here that do not care about anything else but helping someone that needs it, and is willing to accept the help.  I should know.  Many, many folks here have helped me.
Anyway, I just wanted to let you know that MrMag is one of those that is willing to help as he has done so many times here.  I hope you listen to him.
the_big_m_in_ok
Quote from: Pirate88179 on August 30, 2010, 11:24:24 PM
Cletus:
Excellent post overall.  I and others were trying to help you, cletus.  We do have smart researchers here.
--Lee
cletushowell
Im not trying to be a jerk im probly just not explaining the problem or why i need a 120 volt 100 amp ac battery first off
you may have research but have you ever
charged 12 dc batteries with a moray cell
or from a antenna with salt crystals
it turnes to rust very fast it purifys
the lead nuetralizes the acid and fist time theres a open loop
a short in the ground or if you run a motor off it the open loop reverses the antenna and it discharges the battery and fries all the wires
every battery in the system in about 3 seconds
at around 1200 volts because it takes every watt in the dc
battery out at once so much power it
took the plastic off all the wires so i know a bit about why i cant use dc
battery ok the question was please help me build a battery thats not
lead cell that does not purify to rust that can hold 120 volts
100 amps now does anyone know how to do that
so my wireless power can be harnessed
i got it bussing the cap now and basicaly
a welder type sparks and working on converting it to lighting the incandecent
for some reason it will not light it runs the strobe
i had it buzzing the light but miswired it by mistake
im going to study the difference between incandecent and halogen
by the way i peaked ove 10,000 watts across the room
wireless to the amp probe i have a lot of power i donf know how to use it all yet but i will figure it out i will figure out the battery
rebuild the joe cell and power the cars
with implosion because i figured out the principle is the blocking of the carburator creates a vacume the spark pulss the piston rather then jump the gap the distributor moves to the next piston the magnetic feild is broke and reversed at exact top dead center inplosion repulsion or induction
and seperation push pull how ever you want to say it you dont need gas or hydrogen but to start it running
MrMag
Thanx Bill, I appreciate that.
However, I feel that this may be a lost cause.
I keep getting that deja vu feeling about this guy.
