Self-Runner NS Coil Pulse Motor Live Video Stream. It's been going for months!
Started by lasersaber, September 01, 2010, 09:59:28 PM
shylo
Hi all I just signed up because I find this to be very interesting ........If someone such as "lasersaber" can make this work for such a long period of time...does it really matter if its a battery....or if it's wetted...seems to me we have an endless supply of salt water...it seems to me to be a waste of energy arguing.......I tried making one ......didn't work......due to lack of proper materials...........youtube vidieos' don't work for me I'm on dial up ....sucks.........I tried , soft core wound in cotton ,wound a layer of steel wire(electric fence wire)..then a layer of cotton...then a layer of stripped extension cord multiple strands ..........not sure if extension cord wire is insulated or not ,assuming its' not...........three layers of each ...but the winds were not uniform and not tight together..........discussion on the topic is fasinating....arguing about what it is, is a waste of everybodies time ...........lets focous on the topic at hand.........shylo
WilbyInebriated
Quote from: gauschor on September 12, 2010, 03:33:15 PM
To achieve that, I suggest the experimenter performs at least a test with an "amateur faraday cage": Take a cardboard box, cover all sides with cheap aluminium foil from the grocery, earth it, put the device into it. Then lead 2 short wires from the device to the outside of the box and measure again. I'm interested in the results.
really? and that's it? then it's debunked? you and omnibus think a faraday cage is a 'one size fits all' thing don't you... ::)
what you suggest will only short out the e-field of em waves with wavelengths longer than the vhf range... if you knew how a faraday cage works or had ever experimented with one you would know this. what about all the other noise, like 60hz?
Rosemary Ainslie
Quote from: truthbeknown on September 12, 2010, 04:09:56 PM
How much should we bet that none of the experimenters here will do that and film it and post it? Thats been a common problem on the forums that people DO NOT want to show their FAILED experiments. And really, there is nothing wrong with showing the good and the bad results. Its human nature I think to not want to show our failed attempts at anything.
:-X
J.
NOT TRUE.  I am more than willing to report on failed experiments.  And I've seen many threads where experimenters own up to failed tests.  I personally think failed tests are as important as any other - because they're scientifically relevant and required for progress.
Rosemary Ainslie
Quote from: shylo on September 12, 2010, 04:19:51 PM
Shylo - welcome to the discussion.
The trick is to wind bifilar iron and copper.  Lasersaber uses cotton coated wire - and T shirt type cotton between each winding layer.  But interesting to read that pure wire does not work.  did you use the reed switches and the same type rotor?
Regards,
Rosemary
gauschor
Quote from: WilbyInebriated on September 12, 2010, 04:29:49 PM
That's why I call it "amateur faraday cage". I should have added that for best results with the amatuer box one should go outside into the open empty country and then check the device. At least a considerable part of interferences will be prevented this way. But as it is now even the electric distribution boards in lasersabres room can easily cause the coils to collect hundreds (!) of milliVolts. I can do this myself with a simple wire anytime, why should it be different in lasersabres room? You'll certainly understand that this is a huge problem when needing to evaluate the results. Thus my suggestion with the amateur box outside, which shouldn't be too costly.
