Self-Runner NS Coil Pulse Motor Live Video Stream. It's been going for months!
Started by lasersaber, September 01, 2010, 09:59:28 PM
Pirate88179
Quote from: capthook on September 22, 2010, 10:37:53 AM
Hello Bill.
Input Energy = the volts/amps provided from the galvanic reaction > 0
Evidence of that is provided by Don:
And one point I was trying to make was that I see the 'air battery' as a better pursuit over the NS coil because of the many losses I mentioned.
The other is that it would be useful to all of you to provide more data, like DonL has.
Isn't the rpm of the rotor of primary concern/interest yet no where is that detail given?
Once again, I respectfully disagree.  Those numbers posted by Don are OUTPUT numbers not INPUT.  Input to the rotor system yes, but output from the NS coil to which you have assigned these loss figures.  You are talking apples and oranges here.
The primary device is the coil.  The rotor is just Lasersaber's make/break design.  I plan on using a transistor on my next one to see what happens.  No matter what system is used, the coil itself remains the same.
Input still = 0.
dllabarre
Quote from: dllabarre on September 21, 2010, 07:42:39 AM
I haven't posted much lately because I didn't have anything new and exciting to show.
But because everyone is talking about the water and salt I decided to post this.
My 2nd one layer coil: a layer of cotton on core, one layer gal. steel wire, a layer of cotton, one layer bare copper wire, a layer of cotton, a layer of plastic wrap on the outside. NO SALT.  Just Tap Water.
reading:
Volts   Time    Day  Amps
.927V  7:05PM D1
.775V 10:15PM D1  9mA
.658V  6:44AM D2  6mA
.586V  7:23PM D2  3mA
.505V  7:51AM D3  1mA
.501V  6:26PM D3  1mA
.512V 11:20PM D3  1mA
.350V  7:40AM D4  .5mA
skipped Day 5
.300V  6:52PM D6  .2mA
After taking the plastic off of my coil and letting it dry for one day
.0V    7:30AM D8  0mA
Next time I will use distilled water.
DonL
It's been 3 1/2 days since I posted the above message.
My coil has been drying all that time.
Still no voltage or amps.
BUT THERE IS MAGNETIC ACTIVITY.
My coil can still turn a compass.
Now how do you supposed that is happening?
I thought someone said there has to be volts and amps to generate magnetism in a coil?
"My 2nd one layer coil: a layer of cotton on core, one layer gal. steel wire, a layer of cotton, one layer bare copper wire, a layer of cotton"
DonL
IotaYodi
QuoteBUT THERE IS MAGNETIC ACTIVITY.
Your iron wire and possibly your core. Even if your wire was high iron low carbon,which Im sure its not,you would still have some remanence. The common galvanized steel wire is mainly a steel alloy which can become permanently magnetized even with low ma's. A rebar core will do the same as its another higher carbon steel.
What I know I know!
Its what I don't know that's a problem!
dllabarre
Quote from: IotaYodi on September 25, 2010, 08:25:00 AM
I have a ferrite core with this build.
I didn't know ferrite would hold magnetism that long.
DonL
IotaYodi
QuoteI didn't know ferrite would hold magnetism that long.
Depends on if its a soft or hard ferrite. Hard ferrites have high remanence.
http://en.wikipedia.org/wiki/Ferrite_%28magnet%29
What I know I know!
