Magnetolysis - REPLICATIONS ONLY
Started by oswaldonfire, September 02, 2010, 01:27:18 PM
oswaldonfire
The purpose of this thread is to create an area where everybody interested in pursuing Magnetolysis can post about their replications.
TO THOSE WHO ARE NOT WORKING ON A REPLICATION OF MAGNETOLYSIS OR WHO BELIEVE THIS PROCESS WILL NOT WORK FOR ANY REASON: EXIT THIS THREAD NOW.
Bullshit will not be tolerated in this thread.
Please only post hardcore information about progress on your build(s), and put the theoretical stuff in the other thread: http://www.overunity.com/index.php?topic=9448.0.
Be BLUNT and right to the point. If you are incapable of reading, or do not understand, I suggest using the search feature or Google to find out more. This is not the place to ask questions.
That said - let's get this show on the road.
sushimoto
Hi Oswald,
sorry for this "bullshit", but where is something shown to replicate ???
I have read everything from Ehrenhaft up to your theory,
but never found any encouraging setup of Magnetolysis at work.
Have i missed something?
DAMIT DAS MOEGLICHE ENTSTEHT, MUSS IMMER WIEDER DAS UNMOEGLICHE VERSUCHT WERDEN.
ramset
LTbolo
We played with a couple of configurations...about 500 turns of 16 gauge wire on a spindle and a flat solenoid on a small plastic tube, driven with 30v pulsed DC and a full H bridge drive for AC.
Due to the inductance of both configurations, we found it difficult to get very much power into either coil at frequency. It is obvious to me that nearly any coil of a length needed to generate a significant magnetic field is also going to have enough inductance that high frequency drive will be difficult at any real power level. That leaves me pretty skeptical that 17MHz could happen, and even 10s of kHz becomes somewhat challenging.
Contrary to statements made by others, I do not think this is easy. If it works at all...and I am far from convinced...it seems like it will take more than a simple magnetic field. Barring any demonstrations of a system that works, I doubt that we will pursue this further. If somebody comes forward with a working device, and detailed plans to replicate, I would enthusiastically jump back in.
Good luck.
Thanks Grandma
Hope
Hello All,  this is how nature builds and destroys  so I think it is the best method to investigate.   Magnetic induction will place all the items within the field into the same polarity.  But then how do we attract the elements apart?  Heat will widen the helix, but the bonds will have the extra energy from the heat, gravity can do it without so much excitement.  Any thoughts on this?
ramset
Ltbolo
experiment 2
I was messing around in the lab a bit tonight, and hooked up a flat solenoid/plastic tube to my Tesla Hairpin. With the tube empty, it will pull about a 1" plasma arc to ground. With the tube filled with NaOH solution, it wouldn't resonate at all...which surprised me...but then after thinking about it, it really doesn't...I can actually think of several possible reasons why it kills the ringing. I reduced the amount of NaOH to about 3" in the bottom, and was able to pull about 1/4" arc. I left it running for a while but got nothing out.
The hairpin is driven with a 250W oil furnace transformer. The spark gap is about 1"...crazy loud and crazy bright. A 100W halogen bulb lights very nicely when hooked across the bars. Clearly there is plenty of power at high frequency.
I wanna believe guys...but nothing I've seen gives me much hope.
Thanks Grandma
