Crystal Power CeLL by John Hutchison
Started by dani, April 26, 2006, 04:11:36 PM
Koen1
No, I do not know exactly what John H. is mixing in the video,
but I do have a very good idea of what it must be.
Read the "Marcus Reid Battery" posts in this same section, that
should provide some insight into the matter.
I have studied all material I could find about John H.'s 'Crystal Power Cell',
and directly related topics like petroelectric effects, and have concluded
that Marcus Reids 'Crystal Battery' appears to be the same thing as
Hutchisons power cell, just in a slightly different configuration.
Nice thing about Reids Battery is that he has the thing documented
in much more detail than John H. ever cared to do.
In a nutshell, both H. and R. were intrigued by petrovoltaics upon which
they 'stumbled' seperately and in different ways, and both of them set out
to construct a form of permanent battery based on special composition
of a solid, ceramic-like material. H. ends up talking about 'petro-electric effect',
'exotic silicates', 'silicate platelets' and the 'casimir effect', which allow
'electrons to accumulate at the central post'. Reid started out trying calcite-
based compounds and later found that certain silicates in specific situations
appeared to produce the desired effect.
It seems that both of them are basically harnessing e/m fluctuations
inside a material composed of SiO2 and other silicates (Si-compounds),
by exposing the material to electric fields during solidification, which
causes a sort of rectifying effect inside the material, which in turn
causes electrons to accumulate on one electrod. As you must know,
SiO2 is quartz, which is known for its oscillatory properties, and various
arrangements and sizes of quartz crystals (or molecules) can be used
in amplification of ambient oscillations.
Reids battery appears to do just that, and convert ambient oscillations
(e/m and heat) into electron motion.
Hutchisons Cell, if you look at the substance it is made from and the
explanation of its componenets, as well as the output, appears to
be a different form of the same battery concept.
The exact mix of ingredients however, is unknown to me.
If you ever manage to find it, I'd really appreciate it if you'd post
it here!
Regards,
Koen
Koen1
de Lanca,
looks like you got the idea.  ;)
Can you provide a url for some good information
on that Matei Marinescu patent please?
I've searched and not found anything usefull...
Would be much appreciated!
As with the Hutchison/Reid Crystal battery,
and directly related power sources:
I think I know almost exactly how they
work, and how they should be composed.
Thing is, I'm reluctant to tell just anyone,
because it is actually very simple, when you
get down to it. The production process itself is
the tricky part.
But anyone with a good understanding of basic
(read: post 1960s) electronics and electrodynamics
should be able to work it out.
I am certainly willing to discuss the internal
composition of such a crystal power cell,
but only with people who have shown they are
on the level.
Your mentioning of said crystal patents is encouraging.
I'd be willing to discuss the thing in detail,
if you can give me a satisfactory description of
what you think goes on inside the power cell,
electrodynamically speaking.
I'll give you a hint: it seems to be about two basic
processes, that of .......tion and .........tion.
another reason why I do not easily divulge this
information is that I'm working on a version of my own,
still based on the same principles, but yet another
slightly different configuration. Untill I've managed to
produce a version that functions to my satisfaction, I
will not just post this info for anyone. But I will discuss
it with people who can show they know their bananas.
Besides, it's not much use to know how this works unless
you're planning to use the knowledge. And I prefer
people who can understand it to share the knowledge,
instead of multi-million dollar multinational companies who
will try to make more money out of it...
Kind regards,
Koen
Koen1
Alright, think about it...
Shouldn't be hard at all, I've actully already said half of it...
If you know your quartz from your silicates, their electrodynamic
properties and applications, the internal composition is
fairly straightforward. Still complex, mind you, but not extremely
exotic. What is quartz? What does it do? What is it used for?
What other uses does silicium have in electronics? Aks yourself this.
Reid also says it all, in his own way. Hutchison is more
confusing than helpful with his statements. Brown had a good
idea, and his patent applications are very clear.
Brown always used high-K materials in his dielectric experiments.
He found barium titanate to be one of the best dielectrics.
As you must know, he found out how to produce electrically
induced anti-gravity by basically putting extremely high voltage
on two capacitor plates. Obviously, the highr the K, the higher the
voltage may rise before it burns out the cap, hence his high-K
research. He also found that certain high-K materials among
which specific basalt rocks from certain natural deposits, appear
to spontaneously produce voltages, which varied with gravitational
fluctuations. This research resembles H. and R.s work.
Hutchson also used barium titanate in some of his crystal cell versions.
And this material is also a piezoelectric, just like quartz.
Quartz is just so much cheaper. ;-)
Thanks, will search the patent.
Regards,
Koen
