Crystal Power CeLL by John Hutchison
Started by dani, April 26, 2006, 04:11:36 PM
Koen1
Quote from: AbbaRue on March 28, 2008, 01:31:54 AM
As he learns about the cells he finds better ingredients.  Common sense would tell us that.
All the ingredients he has mentioned over the years do work, it's just that some work better.
Well, I think John is qualified enough to simply tell us that if that is so.
I really don't think you need to defend him.
QuoteI believe Johns latest list of ingredients is just the best he has found to date.
I believe he is still talking about the same ingredients and just gets confused now and then,
and that he has not made any cells for years. At least, the only footage is of the same old cells...
QuoteMaybe the next time someone asks him he will give another list, of even better things.
Yes well I was surprised he gave this much info on the radio, so I will be even more surprised
if he ever gives a clear list with exact quantities... ;)
QuoteAnyway, what would be very useful now is a list of sources to buy the ingredients we need.
Anyone know of a good cheap source for the Rochelle Salt?
www.kellysearch.com ?
[/quote]
                                                  EXERGIE-Fusion-Cycle
                                     1Kg molar hydrogen ~ 77 000 000 KWH
              "light/current substance and weight ?Alpha-rad./Beta-rad./........=hydrogen derivate(-s) "
Robert E. Henson
http://v3.espacenet.com/textdoc?DB=EPODOC&IDX=US5252176&F=0
Hawley-"Cube"
http://v3.espacenet.com/textdoc?DB=EPODOC&IDX=US4658171&F=0
Easier to "understand"  and to test: DE .........  Paul Heinrich Marzahn,Muenchen
crystal radio: receiver !   search: emissor ?  LED-like
Fundamentals: Ferdinand Braun,Chandrasekhar Raman, Prof. Florian Popescu
"rainbow"-prisma-effect  : Goethe, Fraunhofer
Exergy-products, actually:
                                    Dr. Helmut Reichelts "Moletherm"-Tapete,
                                    based on his work "Electron-gas-cycle"
                                    www.larbombas.pt  ~ Axergie  spelled: AEs- written: Aix-/Ax ( near Orange)
                                    based on Jacques Bernier- invention
                                    Chemalloy, hydro-carbon et cetera ....
                                    FUSION=(S-)MELTING , Hot or Cold
                                    Water=metal/lic=glance=reflective , but also a  liquid foam
CdL
Koen1
Quote from: lancaIV on March 28, 2008, 08:09:41 AM
I assume you are suggsting we search for that jumble of text?
Perhaps you could say so next time..? Because it is very unclear what you're trying to convey here.
QuoteRobert E. Henson
Yes, interesting. Thanks for that link.
Quote+
Hawley-"Cube"
Not relevant to the topic, is a heat converter. We are not looking for a heat converter.
QuoteEasier to "understand"  and to test: DE .........  Paul Heinrich Marzahn,Muenchen
Interesting if you're into making photovoltaic cells... But we're not.
Quotecrystal radio: receiver !   search: emissor ?  LED-like
What do you mean?
We're after a crystal energy cell, not a LED-like photoemitter...
QuoteFundamentals: Ferdinand Braun,Chandrasekhar Raman, Prof. Florian Popescu
Fundamentals of what?
Quote"rainbow"-prisma-effect  : Goethe, Fraunhofer
I completely fail to see what Goethes colour theory and prisma effect analysis have
to do with our crystal cells.
QuoteExergy-products, actually:
And now it seems you are just tossing a bunch of terms onto a heap...
If you feel there is some connection between all of these things and crystal cells,
can you please indicate what it is??
AbbaRue
I was doing some google searches of Rochelle salt and on the following website
this fellow got 9.6 volts peak to peak from a single crystal just taping it.
http://rimstar.org/materials/piezo/rochelle1.htm
If these crystals were properly placed in a cell with a semiconductor material functioning as a diode it would produce a DC source.
Any vibrations in the area of the cell would cause the production of power. So instead of focusing on the mixed cell idea,
maybe we should focus on Rochelle salt and some form of diode.
Germanium diodes are used in some circuits because of there lower voltage drop to silicon diodes.
Silicon diodes are .5 to .7 volts  were as germanium are around .3 volts.
I also came across a patent that mentioned PbS diodes. (Galena)
I see a patern here both germanium and Galena work as diodes.
Pyrites can show negative resistance and have experimentally been used in oscillator circuits as radio detectors
Zinc oxide shows the same negative resistance curve as the iron pyrite, we can get that from old AA cells.
http://home.earthlink.net/~lenyr/iposc.htm
SO perhaps that is there main function in these cells.
My approach to this is to determine the possible function of each ingredient John mentions.
Then  I can make an educated guess at how to construct these cells.
I strongly believe that this is how these cells work, they pick up any vibrations in there environment and convert it to DC.
We live in a very noisy world so there is no shortage of vibrations to run these cells.
John also hinted towards this on one of his videos.
Koen1
I see much repetition of what I had already posted ages ago.
AbbaRue, although I commend your eager searching,
you have not come up with a different idea for the cell.
The materials you describe are all either piezoelectric
or semiconductive, and most are or have been used in
the mix variations.
If you know your semiconductor and crystal radio history,
all those materials are familiar.
But it's nice to see that you're doing the research, and
appear to want to understand how the stuff might actually
work, instead of blindly following hutchisons vague and
inconsistent descriptions. :)
Perhaps we're looking at our next new actual hands-on
cel experimenter? ;) That would be cool. :D
