Crystal Power CeLL by John Hutchison
Started by dani, April 26, 2006, 04:11:36 PM
KELVIN
I am going to have a go at building one soon, im thinking of using something simple like car wax, soda cristals, and sand, with a copper collector for positive electrons. and the negative im not to sure yet but i did see a person using the carbon rode inside an alkaline battery possibly a very toxic thing to be using, i suppose you could clean it extremely well. or i might use very short peaces of graphite from a pencil lots of them all the way around the cell.
I am a radio ham and do dabble with electronic circuits from time to time.  i do already have a circuit from a previous (anti gravity Lifter) project a few years ago that should give some High voltage to the cell as it sets, its a car Ignition coil being fed via a 2N3055 and has a 555 chip controller all my own design but seems to work well. i dont know how to get high voltage DC . In the video you can hear Huchinson say about applying High Voltage DC ?  and alot of the stuff he uses is valve technology, wonder if its possible to get high voltage batteries used around valves and connect them up in series ?
kelvin
PaulLowrance
Graphite from pencils is good idea. Yesterday I went to 99 cent store and bought one that has 14 graphite 0.7mm rods, you know the kind that fit inside automatic pencils. I tested the resistance of the 0.7mm graphite rods, which showed a short. So that works great. Not sure if all leaded pencils use low resistance graphite, but every one I've ever tested has low resistance.
You can build a simply voltage multiplier -->
http://www.rmcybernetics.com/images/main/pyhsics/voltmultip22.jpg
Each step takes 2 capacitors & 2 diodes. A 10 step circuit amplifies the AC by 10. So if the AC is say 170 Vp-p (120 VAC), then the output will be 1700 volts DC. In this example, each diode and capacitor needs to be rated at least 170 volts.
Another method is to use a Van de Graaff Graaf Generator -->
http://www.youtube.com/watch?v=wqpfiu_TdBQ
http://www.youtube.com/watch?v=NuxGB8sgiNs
Paul
PaulLowrance
Great news:
http://globalfreeenergy.info/2009/09/16/273-073-piezo-update-6/
Today I connected the Radio Shack piezo element, part number 273-073, to a *highly efficient* red LED, part number TLCR5800. The piezo element was successful in lighting the red LED for ~ one second. I was in a dark room for ~ 10 minutes. I would describe the light intensity produced by the LED as being bright, and would wager it could be seen in a dark environment up to perhaps a few hundred yards. After one second, the DC voltage produced by the piezo element was too low for the LED.
It should be noted that the 273-073 piezo was no where near recovered. The piezo had been shorted for ~ a straight month, and then placed in a metal shield for ~ a week prior to the above experiment. This piezo, when fully recovered, will produce hundreds of nano amps for a short period of time, and decaying to hundreds of pico amps where it lasts for a long time to it’s final lowest point of ~ 10 pA. Of course, this is a decaying current, and for ~ the first second the current might be in the micro amp region. That may not sound like much current for an LED, but I was able to detect light from this TLCR5800 red LED down to 10 nA. So 1000 times that is a bright light, relatively speaking, when one has been inside a dark room for ~ 10 minutes.
To recover a piezo or diode simply disconnect it such that *nothing* is connected to it. Place the component inside metal shielding for a long time, at least 2 to 3 weeks.
Although that may not sound like much, it’s definitely one giant leap for mankind.
EE's by profession have verified my claims that shielded diodes produce DC current & voltage, and also have verified the claim that piezo's produce DC current & voltage.
BTW, piezo elements are very stable chemically, made of material such as Perovskite crystal. There is no conventional explanation why a single thin small piezo element should produce over 3 volts and over a micro amp!
Furthermore, the years of analyzing diodes, and now piezos shows their behavior is completely different than electrochemical reactions.
PL
PaulLowrance
