Crystal Power CeLL by John Hutchison
Started by dani, April 26, 2006, 04:11:36 PM
mscoffman
@das and All
Check this link out;
This is an article about a laboratory that has Virtualized the Bandgap
in a bismuth-iron-oxide crystal. Since I have postulated that these
petrovoltaic cells might be receiving photons, this vitrtulized bandgap
might result in much higher voltage battery cells. Also, if this increased
bandgap voltage applies to Planc thermal photons - who knows???
http://newscenter.lbl.gov/feature-stories/2010/03/30/above-bandgap-solar-energy/
(Note: the date on this article- trust but verify)
All semiconductors have something called dark currents - the result of Planc
thermal radiation photons impacting the semiconductor. This bandgap sets
the voltage pedestal in diode junctions and is very important to the operation
of semiconductors and solar cells.
http://en.wikipedia.org/wiki/Dark_current_(physics)
I came up with what I feel is a very interesting question in physics; "Is Dark
matter and/or Dark energy a cosmological implicant of the bandgap in materials
that makes up the universe?"
:S:MarkSCoffman
das aloda bullspit
@ mrbrook
the cell you have made using sealant is it glass in texture? and did you use any form of voltage incued into the cell as it was recooling/crystalizing? try this meatl its alloy name is AZ61 its worked well for me also i have a sealnt cell like yours and its a massive flask that currently produces 1.98volts but the amps are verry low and its not a feasible way to meke it also not verry refined it has no silicon,germanium galena or bismuth rods  only copper oxide coated rod  my dibblie cell is quite good and is repeatable if not always the same effect it needs a higher k material and more semiconductive metals and other things in it also im sure your cell is a real crystal power cell as any eletrochemical reaction last usualy upto a few months and yours has gotten stronger over a year so i doubt it is electrochemical  im going to make a barium titanate galena germanium bismuth beata borate zircon paladium version whith a silver rod inside also ive made a polarization machine from a 2 million volt tase that runs on solr power and also has batteries and switxhes when power is too low nicked the circuit from a beambot web page theydo come in handy 4 somet afterall:) also is your maglite able topower anything have you put any load on it or tested it yet? its handy to know and as soon as i have made some good crystal cells im gonna put a webcam on them and track tere porgress and see how long they last live 24/7 until they die or until i die
or the camera mine do work the problem is they are just too damn big maybe i should scale them down a bit to your size instead of bombshell size
Mk1
@all
Anyone tried putting the cell under magnetic stress in the solidification / electric conditioning phase like a solenoid in series with the power to align the dipole ...
Mark
mrbr00k5
@Das Aloda Bullspit
Yeah, the sealant looks like glass when it hardens. I think I used a 9 volt battery to polarize it. The  cell isn't strong enough to power anything though. But I think I'll try this type of mixture again, and maybe add a few other ingredients. I got some capacitors in the mail finally, I'll use them to make some more cells. They should work better than the maglite because the inside of them is uninsulated. That AZ61 alloy looks really interesting, I'll do some more reading on it, and try and get some. Thanks for the info! ;)
das aloda bullspit
ive had a few improvements in cells as i have dcreased the cell size from massive bombshell to flask and cola can  there is till a long way to go ive tried again the sillica cra filler mix with some germanium niobium selinium barium titanate i use this a lot cause ive got a lot of it to use pyrite in one cell aswel as other coomon minerals in the less refined versions and put one under a bedini to polarize this one acts very wierd one under an intense magnetic field ie a solenoid  and one undera million volt taser machine and i am going to try three more one under intense pressure whilst polarzing one iunder low temperatures or exposed to gamma radition via smoke alarm in a lead box with a hole in  it  an one under various types of soundwaves sawtoth squarewave ect has anybody gotten any closer to making a good reliable non galvanic crystal power cell yet? sitll to improve on the ultra heavy ,massive silicon wafer cell using cpus  still outputting 1.55 volts and still wroks via a direct short only takes 3 hours to recover one ofmy first cells ever made  its the most reliable next to 6 of my crystal cells which are good but too big all power small leds or pager motor fans cell 0 still powering fan after 2months :) and no i donot recycle any of my cell mixes asnot to contaminate for reliable notification in logs textbook always start fresh if mixed together i may not be able to reproduce again and i dont want that i want it reproducable time and time again sot its reliable formula for open source public so people dont think im a fake or a crackpot like hutch i have all my stuff down in books its just i dont organize them very well
