Crystal Power CeLL by John Hutchison
Started by dani, April 26, 2006, 04:11:36 PM
jeanna
@das,
Please keep doing your work and posting your results.
I have noticed many people have left this forum in all threads, so never mind.
I remember the plaster of paris was a good one, but needs more. I think it lost power after a while, but I am sure it shouldn't and just needs more work.
I am watching what you are doing. I think it is very interesting.
Please continue,
jeanna
mrbr00k5
@ Everyone
Hi everybody, I haven't quit coming to the thread. I've just been really busy lately. And my piggy bank is a bit on the empty side to say the least. :-\ As soon as I can get some more supplies I plan to keep trying to improve my cells. Here is an update on some old ones. First, my sealant cells are unchanged, I really do not expect them to ever stop, but they are pretty low power. Usually around 300 milli-volts. I'm going to try and make some more powerful sealant cells, once I get more ingredients.
My chalk cells, are a mixed bag of results. Some are still working, but most have dropped quite a bit. I don't think that they are a very good mixture. I would avoid using calcium carbonate as the main ingredient in crystal cells. I haven't noticed any corrosion or crystals developing on any other cells besides one of my sealant cells and my Lepidolite cell.
My lepidolite cell, as I said before corroded through the zinc container, and white crystals formed on the exterior of it. But I just checked it, and surprisingly it's still outputting 200 Milli-volts. The amperage though has dropped below usable levels.
The lepidolite cell is the one I was using in my little blue L.E.D. box. Since it stopped working, I've replaced it with a AA size cell using calcium chloride. It's been working well for over a month. The duration is about 5 seconds, if I hold the button down, the blue L.E.D. comes on brightly, then gradually dims, over about 5 seconds, finally going out completely. Then, I let the button go, and count to 10, and I can repeat the 5 seconds of light, over and over.
I've included a picture of the hole in the zinc on the Lepidolite cell, and a picture of the type of sealant I use.
Finally, the very best news that I have, is that the flashlight I built is still working. I've left it on to drain the super cap a few times, then turned it off, to make sure it's really charging. An overnight recharge is sufficient for the L.E.D. to be pretty bright, but I would say about 36 hours is needed for a full charge.
Das, you were asking about do any of the cells get hot when shorted. And no, mine never do, I've never noticed a crystal cell get hot, no matter what I did to them. I find it really interesting that the cells respond to lightning strikes, like Ian mentioned. That cell that you hit with 4 million volts sounded really interesting too Das. What I'm interested in is that it seemed to draw energy from other crystal cells.
In T. Townsend Brown's notebooks, which can be found on rex research and qualight systems, In Volume 4 he has an entry titled, Re-Emmision of radiant energy by masses. It mentions a theory he had that rocks were connected somehow, and could absorb and re-emit energy, from one another. Maybe you could check that out and see if any of it sounds interesting, or applicable to what you're doing.
Oh, and just a quick suggestion, has anyone tried powering a S.E.C. Exciter with a crystal cell? Perhaps in the near infinity light system configuration, which needs very little power. I would like to see what would happen.
So anyway, that's about all that's going on with me right now. I hope I'll have something more interesting to report soon. Keep up the good work everyone. ;D
das aloda bullspit
good to see that nearly all cells are uorking the best voltage i ever got from a cell as not 4 volts as that uas a measurement erro it uas 0.4 volts uell .4 volts i had one that did the 6h volts it gave off a static uen you touched the cell it attracted alot of dust but it then uent to normal in half a yer but the most pouerfull cell ever i made uas 2.55 volts and 23 micro ampres or close to that but here is the bad side it uas as big as a small uorlduar 2 bomb because it uas i had that hooked up to a calculator not lcd but a led 70s one and it ran for a hole ueek before it ran out and can still do so today. these uere large prototype cells i got an update about hutches cell so far he hasnt found a investor but one firm uas realy interested in them a small green company and i think he is going to hand the crystal cells over completely to his pupils and let them get on uith it i have seen some materials uat he uses but i havent got a clue uat they are he uoldnt tell me  id ont live near him its all found out  through online chats and his research group is grouing quite rapidly but its a private research team apparently but from uat i sa in one cell it looks similar to some of ours also uen polarizing have you thought of using a hotplate uith a alu plate ontop and uilst its still hot connecting the alu plate to the positive or uaterver and uraping the rod in alu foil and attaching to the negative or uater that could uork i guess  hope to hear more about your neu cells as soon as they get built remeber sent some photos and to all ive said it befor and ill say it again good uark and keep it up
das aloda bullspit
the rversed cell uas really interesting the crystals uere grouing outf the container it almost seemed to suck the energy out of everything and you couldnt even realy red it on a voltmeter it also one three occasions managed to destabilize the matrix in these cells enogh to stop tem from making any energy i polarized thet cell in an accidentally strange uay that caused it to go like that ive tried to get one like that and guess uat no matter hou  and uat i do i simply cannot replicate it and nou it lost in a scrapyard or a rubbish tip better uatch for the neuse mysterious electrical shortages comming from a battery if crystal batteries ever uent global and mainstream this cell uold be like like cyanide to the cells verry feu bounce back after bieng near it this could be a terrorists dream disarming systems uithout bombs and thy ouldnt be able to trace it back at all
das aloda bullspit
@all
Hello Has there been any updates in your cells,and could u send photos
@ian
are you feeling any better? those sulphur cells... hou does the sulphur help to stop gakvanics and could you give me the mixes that used sulpur?
@mrbrook
hope your alrite heard about mone crisis hope your doing ok keep me updated on your cells asuell as the sealant cells im comparing yours to mine and the results are similar have any of you tried taking a piece of basalt or granite and connecting it to a voltmeter and reading to see if there is any vltage? i did uith some koolau basalt and lanzaroti gabbro the basalt had a rerading of 0.4 volts and 1 micro amp i can be sure that it uasnt piezoelectric or pyroelectriccos uen i heated it uith a hair dryer to get ri of any moisture i put it in a moisture  free box and connected the leads to the rock via a metal strip glues to the outside of the bx and the electrodes on the basalt uere both copper i notaced it uas ramadam as deufraise told me and i notaced through these dsay and nealy a ueek the basalt has been fluctuating specialy at night i connected a loda and it ran stilland the voltage had only gone doun by a millivolt do you think taht these lumps of rock could be like  natural crystal battery also ive noticed some thing that others havent it reacts to static electricity and it sometimes pulses at 1mghtz or something like that i think its 1 mghtz its a uierd effect
