FUELLESS CAR PROTOTYPE by ISMAEL MOTOR
Started by luishan, September 08, 2010, 11:50:07 PM
aussepom
Hi
you still ask the awkward questions Mark D,  I know why he can not close loop it, I have the same problem with my MagGen unit, great at charging batteries, lighting up lamp loads,  it even goes better under a heavy load OU 2,
BUT  the type of collection circuits that pump up cap etc, can not be closed looped they collapse.   There is another thing, to long to go into on this post, but the ‘antenna coil’ can no way supply high current on its own, ask the 2M radio hams.
But the MEG is still the interesting part, but the main secret is in the making use of the ‘high circulating currents’ in a tuned circuit, and it seems that he is using a push pull output circuit.  By rearranging to circuit for the coils in the DC motor There is a method in which it could work. I think that Teslar did the same with his ‘own’ AC Motor.
All interesting and yes Poit no one has any thing commercialised as yet.
eisnad karm
Hi Aussie
Mark D is past tense...he and a few others after years of contributions (good and bad) are now under moderation which means it can take many days to have a post approved....well after they are relavant.
However behind the scenes he is still very active and a believer that anything is possible.
Kind Regards
EK
jan.kolar
This thread is clearly the scam. If I would be administrator of this forum I would delete it. Its typical for defrauders in this area that they use very obscure double-talk language. Running his car for 10 minutes in garage should be evidence for overunity? Don't be silly. I also doubt that he used 11 kW motor in his setup. One horse-power (750W) is sufficient for this kind of demonstration. This power range can be successfully operated from bank of batteries (maybe some of them hidden). Dear fans of overunity.com you are missing critical thinking. There is no way you can extract extra energy by shorting coils. This is in contrary to conventional electrical theory. Thats the reason that spice files can't prove overunity. For those that don't know Spice is popular program for simulating electrical circuits. I know it very well because we have it used during my study on electrical engineering faculty. Huge spikes of voltages don't automatically mean more power. It's all in accord to theory U = L * di/dt where L is inductance, di/dt is change of current in infinitesimal small time slice so called derivative in mathematics and U is voltage.
abdusamed
what device does he use to short the circuit at the exact moment????
