FUELLESS CAR PROTOTYPE by ISMAEL MOTOR
Started by luishan, September 08, 2010, 11:50:07 PM
konehead
I've read through the posts here and there is confusion about that "large coil" he uses....
there are two different techs Ismael uses and is demonstrating in videos, and the "large coil" (1 kilo weight) seen in the videos where he blasts  blasts up in air with small battery 35ft high in under second is NOT the type or size of coil(s) he uses in his MEG (motionless electronic generator)
and the MEG is what he powers his car's DC forklift motor with and he doestn use the "repelling force/coil blasting" large type coil in his car.
he has old vidoe mabye two years old where he has car-motor he build that spins car wheel up in ari at 240VDC input from an invertor and input to invertor is 8 amps and 12V and the "output" from the pickupw winds is 15 amps and charging 12V battery - that motor he built has coils "similar" to the large coil-blasting video coils.
the many smaller size coils he uses in the MEG work very similar to HUBBARD method he tells me, and they are wound bifilar-style but with 6 wires  instead ... I think there are total of 200 coils in MEG  but not certain on that...he also has PICKUP/SECONDARY winds around the bifilar coils that pikcup and collect  the "ambient flux" from the large magnetic fields that envelope the resonate-frequency-chopped energized primary coils - pickup winds are actually inside and around the primaries.
In that large coil he blasts up in air with the repelling force, it is bifilar 22GA wires in primary, and 5 paralell 19GA wires on the scondary/pickup winds wrapped all around the primary - these pikcup winds are what give that coil its big size and weight
So he has many small coils in the MEG not one big one. in place of core, there is that inner coil and he says that at high frequencie this inner core works like  an iron core does at low frequencies
It doesnt really matter if someone sits near that anntenae obviously,  its sort of recent add-on feature and is NOT whre the power "comes from" it is jsut an additional thing he added on recently...he told me there are three Power supplies - there are
1)pikcup winds,
2)shorting of coils 5 times at peaks where the oscialltion peaks themselves get shorted - and this is how he gets the exponential power increase and this is the heart of the system..
3)also there is the backemf collection in radio invnterview he mentionn he combines the back emf with the shortingof coils to create a carrier wave and it become sdominate frequency and that is how the anntanae pulsl in power - its my meager opinon that the annatnae could not even be there and he would still be making the huge power he does from "Nothing" in the MEG using only the backemf and shotitng and pikcup winds but if he gets only 10W from anntane and his MEG has a gain of X1000 then that is 10W fiom anntenae so maybe it is some sort of prioming type of thing to feed his system...he hasnt discussed the anntane with me I dont know thatmuch about it but it worked fine when he didnt have one
also the discussion on mosfets not being fast enough I asked him about that awhile back and it is the mosfets are the initiators of the Rings via the shoritng of coils  at sinvewave peaks and it is the oscillations "created" that are the gigahertz speeds and the switches themselves do not have to go that fast....he has very advanced HF RF filters made for his homemade IGBTS
he callls them - filtered IGBTs - "FIGBTS" and without the filters his thing jstu wouldnt do what it does...he has team of topnotch computer chip guys build them for him...
konehead
correction - I meant to type 10,000W not 10W from the X1000 "gain" from his MEG if that anntanes sucks in 10W
figure it is putting out 5 to 6KW right now powering that car with the 60%eff forklift motor so the antennae maybe adds 20% increase?
konehead
also tha video shown above of shorting coil with reed switch is good one, showing simply how to do it with genrator coils incuced by rotor of magnets (should be N-S magnets)...it is better to have FWBR AC LEGS across coil - and if making big power,also have AC cap in series from FWBR to work as high-bypass filter so no lugging at all of motor this way)
Also the power should go into cap wiht no resistance, then cap goes into load in 2 stage process - and cap is disconnected from coil when it hits the load - Ismael does it like this - his forklift motor has NO PLASMA AT ALL in the brushes because the pwoer feed to it is very very clean cl with no plasna/backemf problems burning up the brushes.
Anyways Ismels in his MEG has cap-diacharge that saturates his coils, and at the cap sarutation-point, that is when he hits it wiht the 5 shorts at "peak" which gives the expontnetial power increase AND with no reflecion back to the primary too
konehead
here is scope shot in link below of air-cored coil being shorted at sinewave "peak-period"
this is from testing with a 1200rpm AC rotovertor motor spun generator-rotor of 6 large neodimium N-S magnets that makes the 60hz AC sinewave signal - note the "smears" of oscillations produced by the coil short.
Ismaels more advanced power producing method is he shorts those oscillation peaks themselves...also note the simple solid state circuits if any of you want to try some experiments:
http://sites.google.com/site/alternativeworldenergy/shorting-coils-circuits
here is circuit I use in working motor-generator unit - note it doesnt have "2 stage" output - that AC cap in series working as "high bypass filter" made it non-reflective to motor draw all on its own:
http://sites.google.com/site/alternativeworldenergy/upright-alternator-circuits
Secruoser
Hi, is there a peer review and journal for this prototype? Thanks.
