Electricity Amplification Device - It's so simple !!! (Hatem Magnetic Cogging)
Started by bimbothova, October 13, 2010, 11:40:13 PM
tagor
Quote from: e2matrix on October 15, 2010, 01:20:22 AM
He's also got a new Solid State device uploaded today that appears to create excess power.  Very interesting how simple this one is.  I'm not sure who MindFreer is but I know it certainly sounds like someone many of us know.  Regardless of who it is I think either of these may be worth trying out and if it's who I think then that is all the more reason to believe they will create OU.
Yannick Van Doorne is a very dubiousness guy , look at this :
http://www.overunity.com/index.php?topic=7602.msg185409#msg185409
http://www.overunity.com/index.php?topic=7602.msg185536#msg185536
http://www.overunity.com/index.php?topic=8465.msg214933#msg214933
http://www.overunity.com/index.php?topic=8465.msg214945#msg214945
tagor
Quote from: bimbothova on October 13, 2010, 11:40:13 PM
All the info you need to build a successful overunity device or in other words, an electricity amplification device, is given on this Peswiki page ...
Kudos to Youtube member 'MindFreer' who has uploaded a complete guide book video on this technology ...
http://peswiki.com/index.php/OS:_Hatem_Magnetic_Cogging_Device
I can not peak of  mindfreer
but is youtube 'profile is
    I am a Scientologist and am applying what I've learned in Scientology to the subject of Free Energy. My goal is to present a number of different forms of free energy in an easy to understand format that allows the viewer to replicate if desired or at the very least think about the subject in a different way. If you click on the link to my website you will discover a book I highly recommend to help you in your work, no matter what your occupation is.
gyulasun
Hi e2matrix,
Do not fall victim of scams.  Though it is possible Mindfreer himself believes current transformers give free energy if they are connected in series with a load that is operated from the mains, the person behind ncbookz.com who sold him the plans (see video at 9:50) certainly has been selling his "idea" for a few years now.
This has been the topics on this forum already, see these links:
http://www.overunity.com/index.php/topic,1933.msg38574.html#msg38574
http://www.overunity.com/index.php?topic=5902.msg134091#msg134091
http://www.overunity.com/index.php?topic=9482.0
So it cannot be free energy because it uses the current your normal load (which seems to be tapped) already consumes and you house Watthour meter registers already. The illusion is you do not pay for that current but it is taken from the mains so you pay for it!
Understand?
Gyula
e2matrix
Thanks Gyula,  Very thankful for your input as I know you understand this so much better than I do.
bolt
I am really surprised it took so long for anyone to pick up on this idea here an try it as i looked into to this over a year ago. Already well known in the art magnetic coupling is VERY efficient like 99% without doing anything fancy. The theoretical gain from 3 ring pairing neo magnet drive is 161.8% as magnetic field becomes 3 phases of magnetic flux each shifted by the offset. No accident this is Fibonacci sequence 1.618
According to MindFreer he claims he now has many people who achieved the same results from replications.
quote"After he bought this document, he began to work on a prototype with the plans. I advised him how to make his prototype better too, and with all this he succeeded to make his prototype a working model that doubles the energy in to out.
He is not alone, there are also other people that contacted me that succeeded to make one even better then him but that stays anonymous for the moment. Some are even running their house with like they tell me."
Read Hatem patent and others on magnetic duality pairing. So if you try this you MUST use a drum with 3 staggered neo levels as he has done and NOT one layer to be CHEAP. This is why for about 100 watts i/p the o/p is around 160 watts
Regarding the watt meters the only thing that can upset the readings is the o/p from the inverter is 50Hz 240v and qausi sine. Its not off frequency so well within the spec for the watt meters but the qausi sine creates a few harmonics due to the sharp edges and "may" cause the meters to twitch slightly on the power readings.  The i/p power watt meter is direct from the wall so nothing funny going on here. Its not a looped system but it runs with gain. Looping has many problems and not a simple case of connecting the o/p back to the i/p.
If i were to do this i run 5HP 3 phase motor as prime mover RV to drive 5HP 3 phase motor as generator. In theory at least 1000 watt drive should provide 1618 watts o/p or 618 watts OU using standard off the shelf stuff and o/p 120/240/480 as required. To convert 3 phase to single phase use C2C to match 100% 3 phase loading to single phase.
No need to loop or even convince the trolls or  OU bashers just make quite use of the 618 OU watts for yourself is enough to make major power savings for your house. The entire shebang should cost under 1000 bucks. Going this route avoids expensive cap batteries and inverters and bucks for watts nothing else can touch it.
