Relative Permittivity of Water
Started by Torana, October 14, 2010, 04:35:01 AM
Torana
j
1; Ive seen that video before
2; use  Z = sq root of L/C    .... then use (because Z=X) ...  f = X / 2 pi L .... it illiminates the reso f and Xc formulas , shouldnt take more than a min or so,its the quickest . I already posted it ages ago
Torana
j
**theoretically** the velocity of an electron in AC field = net zero (reso)
search velocity of e in a DC field in a conductor  I/nAq , you might be surprised.
flyback is NOT a step up transformer , it has NO transformer action , it has NO winding ratio, its a POWER INDUCTOR , it completely discharges + has idle time + is 1/2 wave.
*a transformer is incapable of that.
fbt only behaves as a transformer if wired as a mazzilli ZVS push pull non gapped type set up...THEN it has a winding ratio and lower volts out
i already posted links ages ago....
Torana
H,
no where have I tried to stop any one or rip into anyone. havent manipulated anyone into spending their money .
canufi ripped into me , not once did i rip into him, simply because he had nothing going for him. i said he was boring and a waste of space, other than that he seems to be friendly .
  Offline canufi
  • Newbie
    • View Profile
    • http://www.youtube.com/user/canufi
    • Personal Message (Offline)
  Re: Relative Permittivity of Water  « Reply #195 on: June 02, 2012, 11:26:31 PM »  Quote from: Torana on September 02, 2011, 03:23:30 AM
A choke with a wiper arm is mythical other than an air core crystal radio set ,which is normal.
Theres screw slug cores or on a large scale , Ferranti style moving coils.
**Its a Unicorn coil = BOGUS!
You think a variable inductor is bogus? Really?
Quote from wikipedia:
"A variable inductor can be constructed by making one of the terminals of the device a sliding spring contact that can move along the surface of the coil, increasing or decreasing the number of turns of the coil included in the circuit. An alternative construction method is to use a moveable magnetic core, which can be slid in or out of the coil. Moving the core farther into the coil increases the permeability, increasing the inductance. Many inductors used in radio applications (usually less than 100 MHz) use adjustable cores in order to tune such inductors to their desired value, since manufacturing processes have certain tolerances (inaccuracy).  "
he quoted wiki...I posted the same thing in 32 words , clearly he couldnt see it nor google ferranti to save himself....I mean save himself!
again = " a choke coil with a wiper arm is mythical"
the universal symbol for a vari L = a diagonal arrow across a coil
who has used a slide coil and HV?  then again who has used a choke of 11600 ohms?
Torana
  #199 on: June 11, 2012, 10:42:12 PM »   Quote
   Quote from: Torana on June 03, 2012, 03:45:32 AM
Stans "circuits" are for entertainment value only.
Please look up Tony Woodside and Gary Woodside and Irondmax on youtube who have successfully replicated the distilled water and tap water cells which break apart water with the 9XB and 8XA circuits.
= thats what canufi asked....thats what I did .....then he rips into me..nice one!
Torana
If a walmart kettle is 99% eff then what is a water R eff ?
What the hell is a water R eff?  Water resistor efficiency?
...Bingo! ...hes never heard of a water resistor, shoulda googled , they been in use for 50 - 100 years, and Im not talking about 99 % eff kettles....
