Captret - Capacitor and Electret
Started by ibpointless2, October 19, 2010, 06:49:51 PM
gravityblock
Ferroelectricity is a property of certain materials in which they possess a spontaneous electric polarization that can be reversed by the application of an external electric field.  The internal electric dipoles of a ferroelectric material are coupled to the material lattice so anything that changes the lattice will change the strength of the dipoles (in other words, a change in the spontaneous polarization). The change in the spontaneous polarization results in a change in the surface charge. This can cause current flow in the case of a ferroelectric capacitor even without the presence of an external voltage across the capacitor.
Is the Captret displaying ferroelectricity?
http://en.wikipedia.org/wiki/Ferroelectric
ibpointless2
Quote from: Groundloop on October 24, 2010, 02:10:54 PM
@ibpointless2,
I did short out the main terminals on a electrolytic capacitor.
I then shorted the wires to the metal can of the cap.
Every time I remove the short the voltage climbs to
approx. 0,05 Volt. I have shorted out the metal can 20
times now but the voltage always climb back.
I get plus at the metal can and minus at the shorted main terminals.
[EDIT] I have seen up to 0,1 Volt if I let the capacitor rest
          for longer time without short circuit.
Groundloop.
I did what groundloop did where he shorted the + and - and then shorted them to the cap top and when releasing it from the cap top to check the voltage my voltage raises 10 millivolts every 7 seconds. If you short it out again it raises 10 millivolts every 7 seconds and does so every time. The voltage climbs back every time using a 22uF 50V capacitor and groundloops too, and believe it will work with all electrolytic capacitors with a metal top.
Its amazing if it can do that only one time but many times is just crazy! where is this energy coming from?  ???
Just like a electret the captret when fully shorted out will gain power back when the short is removed.
gravityblock
Quote from: ibpointless2 on October 24, 2010, 03:46:04 PM
There is a similarity between electrets and the dielectric layer used in capacitors; the difference is that dielectrics in capacitors possess an induced polarization that is only transient, dependent on the potential applied on the dielectric, while dielectrics with electret properties exhibit quasi-permanent charge storage or dipole polarization in addition. Some materials also display ferroelectricity; i.e. they react to the external fields with a hysteresis of the polarization; ferroelectrics can retain the polarization permanently because they are in thermodynamic equilibrium, and are used in ferroelectric capacitors.  Materials displaying ferroelectrics is very similiar to the properties of electrets.
http://en.wikipedia.org/wiki/Electret
I have suggested that a new category should be added to this forum in regards to the electrets, http://www.overunity.com/index.php?topic=9883.0  Electret is to electric field as permanent magnet is to magnetic field.
[Edit:]  @All, Please help me to get electrets added as a category to this forum.  IMO, electrets or materials with a permenant electric field are equally important as permenant magnets in the quest for OU.
GB
ibpointless2
How to make self charging capacitors!
It must be a electrolytic capacitor.
1) Twist the "-" and the "+" leads together.
2) Get a 9 volt battery.
3) Connect one side of the battery to the twisted "-" and "+" pair and one to the top of the capacitor metal exposed area.
4) hold the battery there for a few seconds and remove it.
5) Un-twist the "-" and "+" pair.
6) Connect meter to capacitor to see voltage
7) disconnect meter and short out capacitor and let sit for a few seconds
8) Check capacitor voltage again to see if it is charging
Don't keep meter on capacitor, it could affect results.
Apply a load or a short and it should bounce back and charge.
This is just the Captret but in reverse.
*The lower the farad's the faster it will self-charge. I used 47uF @ 50 volts but any electrolytic capacitor will work.
Kator01
Hi ibpointless2,
try using electrolytic capacitors with different voltage specifications. The higher the voltage-specification the less charge-losses. Use 100 and 400 V Caps. 400 Volt-Caps are used in flashlight-circuits. Take an old camera fromthe dump an remove this small circuit-board
Will there be a difference in the recharge-speed ?
Kator01
