Captret - Capacitor and Electret
Started by ibpointless2, October 19, 2010, 06:49:51 PM
ibpointless2
I've got some one expanding on the water captret battery idea. This guy has the foil wrapped around the outside not touching anything and he gets some big bubbles.
http://www.youtube.com/watch?v=TLLFk2DZXCA
I'm now trying to make a big enough water captret battery so that it will run some LED's.
gravityblock
You should try to make a BlackGate Non-Polarized Electrolytic Captret, http://www.partsconnexion.com/t/resources/blackgate/blackgate071a.pdf
BlackGate Super E-Caps, http://www.acoustic-dimension.com/blackgate/techEcap.htm
The BlackGate capacitors are no longer in production, but you may be able to find them on e-Bay.
GB
ibpointless2
I took some time off from playing with the water captret battery; I could never find a good way to increase the voltage. I'm back at playing with capacitors and playing with the captret setup.
I noticed something interesting about the captret. I've have the captret + and - leads shorted out and my meter connected to the case and the negative lead. As would what anyone one would expect the voltage goes down when it is hooked up to the meter, but when i touch my finger to the case the voltage will start to go up. At first i thought i was grounding it and that caused it to go up, so instead i touched the other end of the alligator clip that is connected to the case and the voltage went down. So I’m not grounding it when i touch it, so what could be causing it to increase? At first i thought it was the "human electricity" that i was giving off, but then it hit me. I started to blow my hot air from my mouth on to it, and the voltage started to go up. Just to make sure I heated up my hot glue gun, and placed the side of it where it gets hot on to the top of the capacitor and the voltage started going up. It seems the Captret or better yet capacitors are also thermocouples.
Being a thermocouple it could be gathering the radiant heat that sounds up constantly and this could be the reason also for the self-charging we see in the captret circuits. This thermal couple effect could also be the reason why capacitors manage to have a voltage even when shorted out. But this is not that surprising when you start considering current thermal couples and how they function. You see normal thermal couples rely on two DISIMILAR metals while the capacitor has to similar metals but yet still gives off electricity. This also goes along with what I’ve been saying about the water captret batteries; even though they have similar metal they're giving off electricity. It also seems that i may have answered my own question about the water captret battery on how to get more voltage, just add more heat! It seems there is no mystery when it comes to the captret and its extra energy; it’s getting its extra energy from the radiant heat that surrounds us constantly. As for my water captret batteries, they're thermocouples. Not just any thermal couple but what seems to be a very different kind, as you have read my thermal couple uses two of the same metals while normal thermal couples used two dissimilar metals. As seen here. http://en.wikipedia.org/wiki/Thermocouple
You can test this yourself.
I shorted out a 220uF 50V capacitors + and - leads. Connected my meters - probe to the - of the capacitor and the + of my meter went to the case of the capacitor. The voltage was low, around .700 volts but when i touched with my hand or something hot the voltage slowly went up instead of down.
So technically the captret got its extra energy from radiant energy that surrounds us at all time, no matter where you go there is some type of heat.
altrez
Hello,
I think I have replicated the Captret but it does not seem to work? The LED does light but it drains the battery it never has put an extra charge on it? The battery charging circuit I am using on three different size caps will not put a charge in the battery? How long should I wait, its been 3 days?
Here are some pics of my Captrets,
-Altrez
ibpointless2
Quote from: altrez on January 15, 2011, 02:26:56 PM
Hello,
-Altrez
It looks like you're trying to make the "Captret LED Driver Circuit". The Original LED driver circuit was never for overuinty, just to show a different way to run a LED. What made it so different was the way it used the power. When you hook up a normal LED light to a battery the voltage will just keep going down, while the captret caused the voltage to go down but it would reach a certain voltage and start to climb back up but never higher than the original standing voltage.
From the looks of your picture you do have it setup wrong, or at least different than what i normally did. The negative of the battery goes to the case and the positive goes to the positive of the capacitors. The LED's + goes to the capacitor + and the LED's - goes to the - of the capacitor. Make sure that you use a LED and i'll include a simple diagram of the "captret led driver circuit" below.
