Captret - Capacitor and Electret
Started by ibpointless2, October 19, 2010, 06:49:51 PM
ibpointless2
Quote from: Groundloop on October 25, 2010, 05:10:07 AM
@gravityblock,
It seems that this effect is much like the memory effect in rechargeable batteries.
If you drain a lead acid battery fully it will still have a small voltage. It will take
a very long time (shorted out) to remove that voltage. I was thinking of making a small
ocillator to boost the voltage to drive one ultra bright LED. But I need at least 1,3 volt
and approx. 1mA to do that. One capacitor will provide 0,1 volt @ some few pico Ampere.
So I will need A LOT of capacitors in series and parallel. Can't promise anything but if I
find a way to do it then I will post it here.
Groundloop.
There's more than just a few pico farads in it because it was able to light up a red 2.8 volt @28mA LED. It would light up at 1.5 volts and then flash so there is some usable energy in it.
If you want a test to see if it will last you can't use these small voltages. You'll need bigger capacitors with higher voltages. You need to be around 120 volts or more so that you can use a neon as a trigger to light up and short out the load.
Just be careful when doing the test if you use the captret that charges on one lead then disconnects on the other to supply a load. Wrong timing will drain the main power of the capacitor. So you need to find a way that allows you to charge from - to the top and then shuts that completely off with no leakage current then goes to + to the top so you can supply a load and have that completely off with no leakage current. That's going be hard because our modern day electronics allow for such leakage to happen and this is also why our electronics are not as efficient as they should be.
Groundloop
@ibpointless2,
Connect a 1 Mega Ohm resistor. Look at the voltage. When the voltage
is stable, use Ohms law to calculate the countinous current your capacitor
can deliver. I'm not talking about the short time discharge current.
Groundloop.
ibpointless2
Quote from: Groundloop on October 25, 2010, 06:43:17 AM
@ibpointless2,
Groundloop.
But i'm talking about short time discharge current because its a capacitor and thats what it does. I have not attend it to be a battery but instead a radiant energy spike that can be used to charge a battery. And There is got to be more than a few pico farads of storage because it can do real work even though it is just a short flash from a LED. What is important is that it can do many short flashes and then recharge it self. Please don't take offence but you can't expect a century old laws to give you the conventional answer when i'm doing some thats unconventional. If we don't allow new ideas and new ways of thinking then we will never reach overunity because we will be stuck in the past.  I seen what i seen and have video proof of it too, http://www.youtube.com/watch?v=qfbrVHWJwpc.
The short sharp time pulses are what is key, unlike want current electronic books would tell you. The Captret is not what i'm giving to the people, i'm teaching them how to rethink what they were taught and look at things differently so that they are not consumed by sheepherders.
Bobik
Something to think about, AFAIK:
Capacitor cannot change it's voltage in an instant.
Inductor cannot change it's current in an instant.
And if you want a simple way to get energy out when reaching certain voltage you could use Zener diode. There are models with breakdown voltage around 2 Volts.
gravityblock
Quote from: ibpointless2 on October 25, 2010, 09:15:23 AM
It is well known that capacitors have the ability to self-charge, so this isn't anything new you are showing us.  Here's an excellent publication on capacitor anamolies, http://www.distinti.com/docs/cap_anom.pdf
Being stuck in the past may not be such a bad thing, http://www.youtube.com/watch?v=Aos0hnwiHt8  Maybe you need rethink what you have been taught and look at things differently so that you are not consumed by sheepherders, because there are two guys lighting a LED between their fingers in the above video along with other unconventional things by using ancient techniques.  I have seen what I have seen, and I have video proof of it also.  Could it be that the LED lit up due to the difference in the perspiration released by each person's fingers?  A chemical reaction similar to a battery?  We must first correctly understand what we are observing, before we can make it useable.
GB
