Possible overunity generator device
Started by magnetman12003, October 24, 2010, 05:45:08 PM
magnetman12003
Hi All,
This schematic is a Basic Bedini/Davro circuit modified by me that will spin a 2 inch diameter 2 inch thick Diametric ring magnet at super speeds without failing. The spinning magnets flux field is harvested by the Bedini coil and its hi frequency AC output is fed into a full wave bridge rectifier.
----The input power to spin the magnet is almost 1 watt.----
My intent is to generate more power out than what  is used to spin the magnet.  THIS CIRCUIT DOES WORK WITHOUT A HITCH.  440 DC volts is the output as soon as the magnet spins. I am concentrating on the current presently.  Any ideas on what lamps to use that 440 volts DC can power without burning them out?  Remember that voltage will drop when a load is applyed.  Current is presently unknown  I am going to post a video soon on the You Tube.
e2matrix
Hi magnetman,  good to see you are still at it.  I don't know if you have access to European bulbs but 2 of those in series would be a good match I believe.  Or 4 x 120 volt bulbs in series.  You might get away with 3 x 120 volt bulbs also but it would probably depend on how much current you are getting.  If I recall you other setup had high volts but fairly low current output.  You could even try with just one 120 volt bulb to see if there's enough current to do anything as a very low current will not likely burn out even one bulb if it's low enough.  I've put around 50,000 volts across a 120 bulb but at microamps with not damage to the filament.  Nice plasma effects though :)
magnetman12003
Here are the  actual components I used in the output rectifier circuit.
I found a source of 120 volt 1 watt bulbs and  hope to lite 3 or 4 of them as soon as I get their bases wired up in series.  If all lamps light up I will have 4 watts glowing. All 3 or 4 lamps would be powered by a 1 watt input source.  This might be wishfull thinking but I am trying it to see.
The 1 inch diameter Diametric ring magnet does not have enough flux power to lite the lamps. If you plan to construct this circuit you will have to first crack your wallet $100 for the 2 inch magnet. More cash for the other components.
FatChance!!!
Just my two cents.....
Any circuit like this is an "Impossible overunity generator device"
What you show is a regular transformation circuit of electric power.
There no "extra energy" being generated from such a design.
magnetman12003
Hi,
Here are my thoughts on this:  Mind you - no sacred laws are broken.
The Bedini circuit sends a hi frequency AC low power signal to the Bedini coil. NOT SHOWN is the huge 2 inch diameter Diametric ring magnet that is mounted over the Bedini coil. Its attracted to and repells itself away from the WEAKER Bedini coils magnetic field generated by the circuit signal
THAT HUGE MAGNET IS DOING MOST ALL THE WORK. The heavy magnet spin is super fast and if it breaks loose for any reason all hell will follow.
I can see the magnet does the work by metering the INPUT current to the Bedini circuit before, during, and after the magnet spin.  If the Bedini coil itself was push/pulling the heavy magnet spin I would have a lot of current draw. Very little input current draw is noticed.
Having said this what happens next is the  fast spinning magnets extremely powerful flux field cuts through the Bedini coil inducing hi AC frequency/voltage as its back EMF. I would love to see how the stronger magnet induced back EMF partners with the weaker Bedini coils EMF. Guess I will have to save up for a scope.
All AC EMF is directed into a rectifier circuit which converts to DC which can be managed easily.
Its the weak triggering the strong into action.
The Bedini coil has a weaker magnetic field untill it harvests the powerfull flux field off the magnet.
