how do you connect two electric motors together
Started by seekingknowledge, December 23, 2010, 06:04:22 AM
seekingknowledge
Hi all stupid question i know but i have ideas (dont we all) that i wanna start playing with involving tiny electric motors one as a generator one as a drive motor how do you connect the two tiny little drive shafts together? can someone maybe post a video on youtube clearly showing how (have tried looking but havnt found) its done, stepping around lenz law is where my head has been at latley, not saying you can cancelle it completly but maybe harness out put in the correct way you can minimise the effect, i will explain more soon.
seekingknowledge
Also if anyone knows of tiny little accessories and components that can hold them down to a wodden board cos the generator one i want to remove the casing and add more and stronger magnets.
pese
Quote from: seekingknowledge on December 23, 2010, 06:04:22 AM
http://www.designworldonline.com/uploads/ImageGallery/MSSlots.gif
use an spring like the first one
over both shafs (axles)
attentention one way it transfer the power, one way it can running as free-loop)
Pese
Paul-R
Try stripping the plastic off a cable until you find a cable that gives you the
right diameter in the plastic sleeving that gets stripped off. Then push one
shaft into the left hand end and the other in the right hand end.
