cure all diseases using simple self-help method by louis Kuhne
Started by johnnyfg, December 30, 2010, 06:23:47 AM
e2matrix
energia9,  That is not correct.  People are not glass and not breakable by the relatively small temperature difference used in a shower.  The person who gave me this info is also a licensed Chiropractor and has written a book on healing.  As the OP has stated this technique simply uses the fact that when the body is cooled it tends to bring the blood supply into the center of the body.  Heating lets is out to circulate through all parts.  By creating the inrush and outrush several positive benefits are created for the body.  One is moving toxins around to where the body can eliminate them.  I know first hand the benefits as I have used this for many years.
johnnyfg
One interesting effect of using this method (Kuhne) is that a 15+ old scar from a surgery, (appendix) became as if it was done yesterday, even the marks from the stiches, I also felt pain just if there was going on a healing inside behind the scars from the surgery. Fantastic feeling. Like the body finally, after 15+ years decided that it had the strength to heal the scars properly. Now the scars are much more smooth than it have been before I started with the Kuhne-method.
energia9
Quote from: johnnyfg on January 01, 2011, 02:00:08 PM
then please tell me what you are refering to as Hot-cold water,  what is the temperature of these two polarities in celsius,  if this works for you thats fine, thanks for sharing it, i like to know more about the techniques first,   not just by looking at their positive sides, but their negative side effects also
johnnyfg
Quote from: energia9 on January 01, 2011, 02:53:10 PM
I wish I could tell you specific temperatures, but I cant.
It is for me more of a process. I read, and understood, his book, almost like a "formula".
How the body works or should be working, how it transport and digest substances.
This then translated into my world, with my "tools" how to help my body to do its work.
The work of curing itself.
Therefore instead of specific temperatures, it is more in terms of how much one can stand, both hot and cold. If you overdo it, body will protest, and you will not get the desired effect.
Body want and will do its curing, all the time, as long it have the necessary resources.
Your "job" is merely to be an "assistant" to this inner "doctor".
Any changes of temperature up and down, withing reasonable limits, will make changes in the conditions for the body. You will help the body anyway, it is more in the matter of how much you as an "assistant" know what your body want you to do. The higher differences between hot and cold, the stronger will the body react.
If you help your body, and do it enough long period of time, then your body will cure itself.
If it have enough life-force in it.
Try to accept that your body, is built for self-repair, and that your body is part of the magnificient nature and its laws. Next step is to realize that humans as a race is far from completely healthy.
We are born with a huge "list of things todo" ... We inherent weakness from our fathers and mothers. When body cant digest something, it tries to store it temporary in the closeness of the digestive organs. If it become no more room there, then already weak organs will be their new place. Always waiting for a change in the ability to digest is restored to full level. Then it have TRANSPORT these substances back to the stomach and other organs close by. Then DIGEST them, then let them leave the body the normal ways.
This is what the body want to do, all the time, as long as it have the strength to do it.
If you help your body to restore its ability to digest and help you body to transport these unwanted substances back to the digestive organs ... then you will be cured from ALL diseases.
What we call the methods for helping our body to make this come true, is not important for me.
Im want the results talk for itself.
If you are serious, then I suggest you read the book(s) mentioned on my first post on this subject.
There are also some pictures how I practice this in my bathroom using the simplest possible methods.
Im not native English, but Swedish, so therefore I could happen to have trouble to be understood.
But Im here to tell you all who want to learn how to help your body to improve its health.
With love from Sweden and me, Conny.
amigo
@energia9
I think you are misreading the hot/cold, probably due to the language barrier. We are not talking about hardening steel here such as dipping red hot iron into cold water. :)
I have not heard of Louis Kuhne before, but this hot/cold method sounds quite plausible.
Everyone should remember that because body has a large skin surface, there are many nerve endings there and environmental changes are sensed quite rapidly and quite readily. Even slight changes in temperature from the normal body temperature are perceived as hot or cold.
Also, the hot/cold also tells me that we are working with gradients...Gradients mean we have motion, and if you recall, the motion (moving charge) produces fields and currents. Hold that thought for a bit in your mind...
