cure all diseases using simple self-help method by louis Kuhne
Started by johnnyfg, December 30, 2010, 06:23:47 AM
johnnyfg
Hello! I have been using a old method to help the body to heal itself. Invented by Louis Kuhne. He lived in Germany, Liepzig. By using hot and cold baths according to his suggestions, help the body to transport and digest toxit substances in the body, and then transport them out of the body using the normal ways. He states that if we could ask the body itself, it would say: "there is only ONE disease, toxit substance in the body". This single disease, can be cure with one method, thus: all diseases can be cured, but not all sick. Since the body have to have enough life-energy still present.
But this is way much better, than any other normal and alternativ method ... since they focus on specific diseases. Also this method is so cheap since you have practice athome in your bathroom using the simplest methods. By using these methods since nov-2004 I have been releaved from several "incurable" diseases like, scoliosis, dry skin, digestive problems, hip not horisontal, bad self-esteem etc etc. Cancer and AIDS belong to the group: "all diseases", therefore is it curable using this method. As long as the body of the patient, have enough life-strength still active.
"science" tend to forget the will-power of the body to cure itself, instead we turn to educated person wearing a white coat with fancy diplomas on the wall, for answers.
http://johnnyfg.zoomin.se/ is a webpage, mostly in Swedish, but it have a english PDF, and also some pictures how I have done when I have helped my body to heal itself.
e2matrix
A Master herbalist told me about this same type of technique.  Run water as hot as you can stand it for one minute on a problem area, then as cold as possible for one minute.  Keep alternating this way for 15 minutes.  It causes your system to rush blood into an area when hot and rush out when cold so it pulls out toxins rapidly.  Drink lots of good water when doing this or after doing it.  Great healing technique.  Jim Humble's MMS is also on top of the list of great and very cheap (like the hot and cold water) techniques for healing that you will never see doctors or the pharmaceutical companies use as they are so cheap to do they could never make their gross (and I mean gross as in puke gross) profits with these methods.  Always good to hear another self healer success story.
johnnyfg
Water in nature moves with changes in temperature, this also is the case in the body.
The water treatment in Louis Kuhne-method, is two-fold. Hot to make things more moveable, cold to encourage body to transport garbage to the middle of the body, where the only organs that is capable to digest the garbage. But yes, hot/cold on any acing area, also give atleast a temporary calmness. Same as accupuncture, massage etc. But curing, only the body itself is capable to do that.
energia9
 do you know what happens to substances when you apply high heat and then quickly cold, they will shatter and break apart ,  it is not a good thing to do with the human body,  it quickly expands then shrinks, this huge difference causes your skins pores to quickly open and close,     since your body is allready hot  35 celsius degrees,  you should shower with only cold water,  this has been told me by my old Sport teachers,   hot water raises blood pressure also, also if you know how train roads are welded together in some areas where a big temperature difference would brake them apart and create a space between them,  becareful with too hot and too cold water,   i know this is absolutely not healthy to your bones either,   the human body can stand these high differences up to a certain point....
