Advancements in Vortex Mathematics
Started by GregorArturo, January 04, 2011, 07:12:24 PM
GregorArturo
Hey everybody, I haven't posted on this website awhile and I felt it was worth sharing some new advancements in vortex mathematics from my research contribution along with others. This information has been shared already with the YouTube community along with constant discussion on the rodin coil group on google.
So the math has revealed that the 1st dimension is magnetic with three components: Scalar, north pole, and south pole energy. Overlapping magnetic fields cause the twisting of the magnetic fields to cancel out, the doubling circuits, leaving only the scalar component, a true one-dimensional string of energy.
By grouping these three sequences it creates a 2D matrix that can be folded in onto itself to create a toroid. The base matrix is 6 x 6 which creates the yin yang and flower of life type flow. This 2D matrix creates a 2nd axis of information which is electric in nature. The Yin Yang is an oscillation of polarized charges.
There are 3 unique and distinct 6 x 6 matrices. These translate into three toroids which interlock with each other forming the celtic knot the Triquetera. However, this is usually seen as one flow, a type of mobius strip. It is 3 distinct toroidal flows the work together to focus or funnel a single magnetic flow into a vortex and implosion. The three toroids are out of phase with each other, a concept Tesla completely understood.
Each toroidal map creates a unique 18 number sequence (which each map contains two of) that represents the oscillating flow of electricity. If you take each three sequences and make them out of phase with each other, you create a 18 x 3 matrix that can further lead to create a 6 x 6 x 6 matrix depicting space and describing the flow and patterns of light.
Currently, I am working on connecting the Fibonacci sequence which is a 24 number cycle in vortex mathematics to the fourth dimension to unify the lower dimensions in terms of how energy flows in, between, and out of them.
A single toroid works only as an oscillating pump with no net energy to say extract as free energy. By elevating the geometric complexity, to allow these pumps to funnel in a specific direction, net energy can be extracted.
There's much more to this than meets the eye, and than what I've already shared. My YouTube channel describes more in detail at http://www.youtube.com/gregorarturo85
I'm just hoping to see some thoughts, and see what things people may build! Feel free to ask any questions. I'll share more on material sciences later in relation to these flows.
Omnibus
This is certainly beautiful math, especially presented visually. What isn't clear is what is its connection with physics. What gives you grounds to attribute physical meaning, say, talking about energy, when presenting these mathematical results?
MrMag
Nice work Gregor. And just ignore the troll.
Omnibus
Quote from: MrMag on January 05, 2011, 07:32:25 AM
The above is written by a troll.
GregorArturo
Omnibus, you are absolutely right. The hardest part about the math has been the interpretation of the abstract patterns in terms of their relationship to attributes to our physical world. However, by creating the dynamic systems the math dictates, you are able to see how certain patterns flow versus others. The 1st dimension has three fundamental properties which fit most appropriately with magnetism. The 2nd dimension oscillates between two opposing energies and applies most appropriately to electricity. When looked at from a holistic perspective, it connects everything together rather flawlessly which is a statement in itself.
To explain how three triadic coils linked together would be replicated here, it involves making the three toroids out of a diamagnetic material. This pushes the magnetic field out of its core, or curves it away from its core. Each toroid has its own intrinisic internal magnetic field that all feed off one external magnetic field. If you lined up the triad so one of the three outer arms faces your closest magnetic pole, then there would be a vortex street effect happening on that point with two opposing vortices fishtailing off the toroid and into a cylical flow around the structure itself. A paramagnetic material could be used to guide this magnetic energy through the hole of each toroid. So essentially the hole of each toroid contains 2 diamagnetic toroids, and smaller ratio paramagnetic toroid which feeds through all three diamagnetic toroids. In the central shaft of the entire structure, a ferromagnetic material can be used to focus and implode the external magnetic field. What this doesis create a drain for the earth's magnetic energy (or any other input magnetic energy you are using) which it vortexes, causing it to accelerate toward singularity.
You don't technically have to wind the toroids. It's a concept like Tai Chi but with material science. I'm currently working on construction of one right now.
So study this animation good. There's going on right there.
http://www.youtube.com/watch?v=geKTEwd8II8
