Thanks to ALL for your help!!
KMD - Kehyo's Magnetic Disruptor
Started by kEhYo77, January 13, 2011, 05:00:36 PM
kEhYo77
Today I started building a new configuration. The one in previous post was my first try and I had to make few adjustments. I salvaged two more ‘transformers’ from broken PC power supplies. It appears that many of them use similar components, so I have enough identical core material to work with now. It is quite hard to rip apart the coils but it is doable. I came across 2 different shapes of core pieces: C and L. Both of them have little slit in the shape of a triangle, right where my DIY bobbin is positioned.  I filled that with powdered iron mixed with epoxy to fill this space.
The input coil this time will be wound close to perfection when it comes to geometry. I will be using two layers of wires, 16 wires per layer to form 3D Tesla bifilar pancake electromagnet. I think that the best way to connect all those wires is to make 2 interleaved sections 8 wires per section soldered together for handling high current.  So it is going to be two multi strand isolated cables per section making sort of a bifilar tape. I will have two such tapes obviously to make pancake coils. I predict high efficiency and quick magnetic field build up as a result of this configuration.
kEhYo77
Today I was browsing through google patent database and look what I've found:
http://www.google.com/patents/US20120161917
it looks like this one is based on my idea from Feb 2011, what do you think about it?
gyulasun
Hi Kehyo,
In fact, the patent application you found has 'strong similarity' to an even earlier prior art, the so called Bulgarian MEG which exactly includes toroidal or rectangular closed cores in the outside MEG columns.  See this thread here with pictures:
http://www.overunity.com/4300/a-truly-overunity-transformer-meg/
There is a Bulgarian patent on it, applied for it in 2006, see here:
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=1&ND=3&adjacent=true&locale=en_EP&FT=D&date=20070630&CC=BG&NR=109554A&KC=A
(unfortunately you have to pay for your local patent office to be able to have it fully)
You could inform the USA patent office about your and this Bulgarian prior art (you may get help how to proceed at your local
patent office).
Gyula
The US20120161917-patent requirement/application disillusionate me cause the inventor write about a 95-105% efficiency ( very good for a transformer and this power range :2-3W ,but ) not near the COP 2,5-3,.. from Valeri Chobanovs experiments !
An easy "MEG" as structural part from a motor concept  showed this publikation,inventor Heinrich Kunel  :
http://worldwide.espacenet.com/publicationDetails/mosaics?CC=DE&NR=3101918A1&KC=A1&FT=D&ND=3&date=19820819&DB=EPODOC&locale=en_EP
Figure 6/7
Something from an ex-chief-engineer from Siemens, Dr. Wolfgang Volkrodt ,working in the 5000Hz range:
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=16&ND=3&adjacent=true&locale=en_EP&FT=D&date=19860717&CC=DE&NR=3501076A1&KC=A1
Sincerely
                 CdL
