Rosemary Ainslie circuit demonstration on Saturday March 12th 2011
Started by hartiberlin, February 20, 2011, 06:14:05 PM
MrMag
Quote from: WilbyInebriated on June 25, 2011, 09:05:53 PM
i noticed you didn't answer any of my questions...
how about you do a bit of your own due diligence mr. mags? is there something preventing you from reading the time stamp on the post by aaron @ energeticforum other than your love for speculation and assumption? for your lazy convenience, it was posted in early june of 2011... as far as steve's qualifications, you can do you own due diligence there as well... ::)
Yes, I did see the date but thanks for reposting it. Is it speculation and assumption or are they still part of the "team"? I really don't need to look into steve's qualifications. He is an irrelevant pawn in this "team".
and as far as i've seen tinselkoala is nothing but mouth... does that now discredit him? or is it only your opinion of someone that is the final arbiter?
I don't know enough about Tinselkoala to think either way about him. If that is your speculation and assumption, so be it. I am not completely sure of your last comment but it sounds to me that maybe steve is the last team member. Doesn't surprise me if this is the case.
The one thing I don't understand about this team is why are they interviewing each other. I would think that a third party or some independent person would have done the interviews.
ADDED:
FYI, I want to take back what I said against Steve. Although I still think he is being used as rosy's pawn, he has written some very informative documents.
WilbyInebriated
mr.mag, why are you avoiding answering the simple questions i asked you?
MrMag
Quote from: WilbyInebriated on June 25, 2011, 10:29:17 PM
Maybe i'm waiting for your friend rosey to answer mine first.
Rosemary Ainslie
Dear Wilby,
It is my opinion that you're doing Mags a gross injustice by assuming he is capable of any kind of reasoning.  He, like Cat and even Poynty - still think that I can power up my circuit and let it run for months without supervision.  I've explained that this is not possible.  For some reason the settings 'slip' and and within minutes the temperature on the resistor element reaches dangerous levels.  This 'danger' can be lessened while that element is inserted in water.  But over time, that water will evaporate and under conditions of heat it will evaporate 'at speed'.  Within a brief 2 hours most of that water will have gone.  Then?  What does one do?  Let the 'hot' part of the element melt the plastic container?  And then everything around that element?  But then - OBVIOUSLY - we can insert the element in that much water that it never reaches boiling point.  Which also means that we could also never prove how much heat was being dissipated.  The only way to run the test that Cat, and Poynty DEMAND is that we run it under close supervision.  I'll do this gladly.  Just pay me to make it worth my while.  Because I KNOW that no-one who matters even asks for that test.  And to DEMAND that I run it is PROFOUNDLY UNREASONABLE unless, obviously, there's some promise of recognition for those test results.  And I CERTAINLY don't mean recognition by Mags or Cat.
Kindest regards Wilby.  Clearly you're tireless.  Me - I'm not so much any more.  This is all getting more than I can manage.
Rosie
happyfunball
Quote from: Rosemary Ainslie on June 25, 2011, 11:03:46 PM
Dear Wilby,
Rosie
Can you state unequivocally at this point that there is no battery drain in the period of time required to boil water? If not, someone is going to have to do that test.
