Mavendex
Hey Mags,
Its a Peavy CS-1000 power amplifier, 2 channels 2ohm min load, 39 volts stereo or 49 volts bridged
My primary got to 1.7 this time around.. insulated wire to try and keep the shell from saturating.
1.0 on the secondary the ceiling was still there. but it was 48 volts this time can never get above it... when its wound its wound. at least thus far
Mav
Mavendex
oh btw mags, Ive never had any luck with the russian doll setup as of yet let me know what you come up with
Aphasiac
Quote from: e2matrix on May 02, 2011, 06:58:21 PM
Attached is my conversion of the .doc file (135 Kbytes vs. 419 Kbytes for the .doc file - another reason I prefer PDF's)
@ TAO: Great work, and thank you!
I have a question on the following excerpt from your doc:
"Primary (outer) toroid:
LOW (but not zero) permeability metal; mild steel or cold rolled steel work well, also
automobile exhaust donuts (which are readily available from muffler shops) work well
for this the upper and lower halves of the shell are NOT electrically connected, but they are
mechanically connected; there may be a gap between them for cooling purposes
wire should be wrapped counter-clockwise (see diagram); normal magnet wire so far has been shown to be best
______________
Is this correct? My current understanding is there should be no gaps, else you end up with a transformer. Should the outer shell not be welded or epoxied completely shut? Mav?
Thanks, Aphasiac.
The real voyage of discovery consists not in seeking new landscapes, but in having new eyes. --Proust
Mavendex
Im not gapped at the moment just electrically isolated, I guess it would all depend on how thick your shell is or how far away your wire is at least from my experience.
Magluvin
Hey Mav
Very cool.  Its funny though, I think Im dealing with the same problems as the shell game.  ;]
I find it interesting that adding a core to the secondary, that the sec can be shorted and no extra draw from the primary.
So Im hoping the amp and testing will help me also. ;]
Would be interesting if both styles end up good.
Im going with 2.2ohm 30awg windings for amp purposes.
Mags
