Mavendex
I was useing 16, but the heating of the wires came in to play and so I switched to a 9 gauge to allow the amps to flow a bit better without being restricted, and it actually helped alot I could dump more amps in and use alot less voltage.
I tried a Galvanized steel pipe with a Iron stake all wrapped up and got no energy transfer out of it much like the iron cores that I also tried, Iron just won't work unless your talking in a massive scale is my personal opinion.
Magluvin
Hey JS
Here is the pdf I told you of.
Does anyone have the Tesla pat. no. of his transformer?  ;]
Mags
the_big_m_in_ok
Quote from: Magluvin on August 03, 2011, 01:01:26 PM
Hey JS
Mags
@Mags
Did Tesla patent anything like that?  Wait.  He did have something that had a coil inside a toroid, I think.  At the very least, there are a few patents like the .PDF that was posted.
--Lee
JouleSeeker
Quote from: Mavendex on August 03, 2011, 10:30:09 AM
Wow, 9 gauge...  How many windings (or feet) of 9 AWG did you get on the toroid?  9 gauge for both sec and primary?    that's some heavy-duty wire!
QuoteI tried a Galvanized steel pipe with a Iron stake all wrapped up and got no energy transfer out of it much like the iron cores that I also tried, Iron just won't work unless your talking in a massive scale is my personal opinion.
   So I take it you're saying that something like permalloy is needed -- right? what did you use, if I may ask?
Thanks, Mags -- I'm reading the .pdf with interest.  I have some thoughts on speed-of-light constraints in the "expansion" of the changing B-field also... could be quite interesting.  I'll see if the .pdf gets to such relativistic effects which I find fascinating.  Anyway, I'm thinking this through... lots of fun -- thanks!
Magluvin
Hey JS
Here is a link to the pat.
http://www.teslauniverse.com/nikola-tesla-patents-433,702-electrical-transformer
Here is an excerpt ...
Figure 1 is a cross-section of a transformer embodying my improvement. Fig. 2 is a similar view of a modified form of transformer, showing diagrammatically the manner of using the same.
A A is the main core of the transformer, composed of a ring of soft annealed and insulated or oxidized iron wire. Upon this core is wound the secondary circuit or coil B B. This latter is then covered with a layer or layers of annealed and insulated iron wires C C, wound in a direction at right angles to said secondary coil. Over the whole is then wound the primary coil or wire D D. From the nature of this construction it will soon be obvious that as long as the shield formed by the wires C is below magnetic saturation the secondary coil or circuit is effectually protected or shielded from the inductive influence of the primary, although I would state that on open circuit it may exhibit some electro-motive force. When the strength of the primary reaches a certain value, the shield C, becoming saturated, ceases to protect the secondary from inductive action, and current is in consequence developed therein. For similar reasons, when the primary current weakens, the weakening of the secondary is retarded to the same or approximately the same extent.
Mags
